Results 31 to 32 of 32
Thread: Welding day are over
30th Apr 2022, 09:56 PM #31China
- Dec 2005
- South Australia
- 1,658
That is what the nurse said exactly, that most of the doctors would not even know what welding is, shielding has been tried in many forms as yet nothing has proved satisfactory.
There is no need for me to have some one else with me ( although the way you put it does sound tempting, it's ok my partner does not read this ) it is very unlikely to cause a life threatening situation, I will simply receive a unwanted shock in which case I simply stop welding.
If I do have to give it up I am extremely well versed in Oxy/Acetylene use, more so than MMA.
30th Apr 2022, 11:09 PM #32Most Valued Member
- Healesville
- 2,129
I guess if you stick to using 2.5mm rods then you can keep the amps low enough but if you wear glasses then you might need to find a pair that work at arms length and then you need to remain vigilant about keeping your distance.
Tho i suppose that after you have had a couple of boots you should know the distance sweet spot, it would sorta work like those zapper dog training collars.
Welding using a gen set.
By TrevTronic in forum WELDINGReplies: 12Last Post: 23rd Aug 2018, 09:10 PM -
C02 for Mag Welding
By toyota254 in forum WELDINGReplies: 20Last Post: 13th Jun 2012, 04:56 PM -
QUEENSLAND Welding kit.
By bobbo in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 13th Feb 2012, 10:00 AM -
Welding 5mm SS rod for BBQ with Oxy
By Paddy in forum WELDINGReplies: 4Last Post: 2nd Feb 2012, 09:43 PM -
new to welding.
By Bluegum in forum WELDINGReplies: 8Last Post: 24th Oct 2006, 09:22 PM
