Results 1 to 3 of 3
Thread: Mice proofing trim deck
27th Dec 2021, 10:03 AM #1Novice
- Jun 2020
- Brisbane
- 21
Hi All
is there a best way to mouse proof trimdek cladding around the base of a workshop slab? As in the holes left by the profile around the outside of the slab.
I finished my workshop (finally) and I’m now adding some insulation and plywood wall lining but really don’t want mice to get in behind the walls and make a mess.
Thank you for any ideas. Currently thinking maybe spray foam or a right angle flashing that I could attach under bottom edge.
27th Dec 2021, 10:31 AM #2
There are a number of commercial solutions, I have this type of product on custom orb sheeting.
https://shedblog.com.au/vermin-seal-...oof-your-shed/
5th Jan 2022, 07:29 AM #3Novice
- Jun 2020
- Brisbane
- 21
Thank you, that does look good! I might have to remove the internal lip though and hold it in place with the screws through the sheet (panel form shed). Mine might extend slightly too far past the edge based on the pics.
They don't teach electrical safety at mice school
By Ray-s in forum ELECTRICALSReplies: 5Last Post: 7th Dec 2021, 08:35 AM -
Advice to make circular metal trim
By Swinginghammers in forum METALWORK PROJECTSReplies: 11Last Post: 11th Nov 2018, 09:29 PM -
Line shaft Mice
By DSEL74 in forum ANTIQUE AND VINTAGE MACHINERYReplies: 14Last Post: 17th Sep 2015, 05:58 PM -
Rust proofing steel lintels
By Gotta Plan in forum METALWORK GENERALReplies: 7Last Post: 1st Aug 2011, 11:56 PM
