Results 1 to 15 of 22
19th Dec 2021, 02:51 PM #1Most Valued Member
- Charlestown NSW
- 1,673
Update on a good hand cleaner request
There was a thread about 4 years ago asking for recommendations for a good liquid/paste hand cleaner.
I'm just wondering if anyone can do the same for stuff currently available.
I'm just about at the end of a 5 litre pump pack of liquid Solvol which I will not be buying again as its really only good for hands that are not very dirty. Plus the supplied pump keeps clogging up and has to be disassembled every couple of weeks and cleaned out. If I used it every day it might be ok, but its mainly only weekend use. Even so, surely it cant be that hard to supply a pump that will last to the end of the container.
I also don't want anything with micro beads in it. Pumice is fine.
So any suggestions?
Thanks in advance
Peter
19th Dec 2021, 03:47 PM #2Philomath in training
G'day Peter
That might have been a thread that I put up. The current one I'm using is a ChemTools hand cleaner. It was good enough that I recently bought another bottle of it -
https://www.chemtools.com.au/product...-hand-cleaner/
There is also a mint version. Apparently the same thing but with different colour/ fragrance.
PS - they do a 500ml bottle. I decant into that from the larger container. No clogged pump to worry about.
19th Dec 2021, 04:35 PM #3Most Valued Member
- Charlestown NSW
- 1,673
Thanks for the info Michael.
What sort of price is it?
There is a reseller about 100 metres from where I work so I'll probably buy some after xmas.
peter
19th Dec 2021, 05:47 PM #4
Lately (last couple of years) I have been using small bottles from Supercheap. Yeh it works reasonably well but it is not as good as Protectalene. This stuff was really good for grease, oil and even paint (Turps based). No one up this way sells it anymore. It did get a little dear but it worked so well.....lament
Just do it!
Kind regards Rod
19th Dec 2021, 06:07 PM #5Philomath in training
A 5 litre bottle is around $40; a 500ml squeeze bottle is $7.50 (SA Alltools)
Original thread was https://metalworkforums.com/f65/t200...s-hand-cleaner
19th Dec 2021, 06:36 PM #6
At the steam depot (where it's possible to get unbelievably dirty, just ask my better half) we use Septone Protecta Grit hand cleaner. I use the same stuff at home, it makes the difference between being allowed in for tea at night and having to sit at the back door whining...
It comes in a 20 kg drum and you can use a normal drum pump to dispense it. It shifts the most recalcitrant heavy greases and soot.
19th Dec 2021, 09:18 PM #7
FWIW I use "Swarfega" 500 ml pump bottle from supermarket ! If I need something a little stronger I dip my fingers into the wife’s washing powder !Best Regards:
20th Dec 2021, 12:39 PM #8Most Valued Member
- 2,672
I’ve been using Lightning Scubber.
They do a version without the pumice too.
A 4kg tin lasts about a year for me. I just leave the lid on loosely and running the fingers of one hand across the goop is usually enough to wash both with.
https://www.totaltools.com.au/2741-l...d-cleaner-390i
20th Dec 2021, 04:32 PM #9Member: Blue and white apron brigade
I often end up washing my hands sometimes 5-6 times a day and find I can't use strong soaps as the wrecks my "thin" skin so I use Glitz Hand wash from Bunnings, $30 for 5L.
It contains orange oil which is a good solvent for grease/oil.
For really ingrained dirt I keep a bar of Solvol on hand but only use that say once at the end of the day.
Another trick is to get half a lemon and crush the skin up so the oils come out.
Between the oils and the citric acid this really gets the black out from under the skin and around the nails.
Increasingly I'm using some form of glove which also helps
20th Dec 2021, 05:20 PM #10Most Valued Member
- Jul 2016
- 35
- 1,522
I can really reccomend rather than an aggressive hand cleaner I use a Wurth hand protecting cream. I work on filthy stuff and it really makes washing off easy. Need to wash off and reapply after a couple of hours but is good stuff.
20th Dec 2021, 09:25 PM #11Pink 10EE owner
- 6,218
I use Septone Protecta pink.
21st Dec 2021, 06:07 AM #12
Zep products work well. If You have Them over there.
21st Dec 2021, 10:52 PM #13Diamond Member
- N.W.Tasmania
- 1,407
If you know anyone into making bio-diesel, beg them for some glycerine. It is a byproduct of soapmaking and bio-diesel production. Wet your hands with water, shake most of it off, then just add a small amount of glycerine and rub around fingers and finger nails to loosen the crud. Rinse off for really clean hands and soft too like a baby's bottom. Apparently soap makers remove the naturally occurring glycerine from the soap that they make, and sell it to the cosmetics industry, it's a high value product.
21st Dec 2021, 11:40 PM #14Member: Blue and white apron brigade
I bought a 1L bottle of pharma gradeglycerine back in early 2020 when I was making hand sanitzer and still have most of it - so I might give it a go.
I think I paid about $30 for it but it can be had a bit cheaper $25/L these days, or $40 for 5L, that's for Pharma grade stuff - I wouldn't use it otherwise..
Most of the glycerine I've seen is usually made from Canola or Soya beans.
22nd Dec 2021, 09:05 AM #15Diamond Member
- N.W.Tasmania
- 1,407
G'day Bob, I remember that my mother had a jar of the stuff for years, it was like clear honey in appearance, clear as water, while the stuff that I have used is like soy sauce in colour and like runny honey in viscosity, somewhat thinner than my mothers jar as I recall. I never had anything to do with mums glycerine unfortunately, and have no idea of what became of it. Although strongly coloured, the stuff I have doesn't stain at all and washes away very easily. Give yours a try, I think that you'll be surprised at just how good it is.
Steam cleaner
By China in forum METALWORK GENERALReplies: 16Last Post: 11th Jan 2021, 02:24 PM -
Suggestions on hand cleaner
By Michael G in forum METALWORK GENERALReplies: 47Last Post: 22nd Jun 2017, 10:35 PM -
Quality hand tools at very good prices (pretty big range)
By FenceFurniture in forum METALWORK GENERALReplies: 0Last Post: 20th May 2015, 09:07 PM -
Hand Scraping a Hand Plane to .0001" Accuracy
By Ulma Doctor in forum METALWORK GENERALReplies: 4Last Post: 28th Feb 2015, 06:38 PM -
tin snips-left hand or right hand?
By 3 toed sloth in forum METALWORK GENERALReplies: 39Last Post: 18th Mar 2012, 04:07 PM
