Results 1 to 3 of 3
Thread: Garden Shed Build
26th Oct 2021, 06:19 PM #1Most Valued Member
- 70
- 1,511
Garden Shed Build
I may be building a new garden shed for brother. It will be 3m x 3m. I have this idea about building it above ground supported by four L-stirrup post support tubes 500mm long that I will make from 50mm gal pipe, flat plate and 50 x 200 angle or off the shelf brackets. Some water flows through the area where shed will be sometimes and above ground will be better than a slab. The idea is to concrete the four stirrups into the ground with a footing of 300 x 300 x 600 depth. Two three metre 200 x 50 sleepers will be attached to two of the stirrups on each side and another two sleepers 200 x 50 x 2900mm bolted to these between the ends. Frame will be timber with metal sheet of some sort for walls and roof. The question is, will a footing of 300 x 300 by 600 be adequate? Soil is fairly sandy.
Stirrups will be similar to these -
https://www.advansa.com.au/productimages/LSPS50300.jpgNev.
26th Oct 2021, 06:26 PM #2Most Valued Member
- 70
- 1,511
Forgot to say the stirrups will be in the footings to a depth of 300mm allowing a gap under the sleepers to ground level of 200mm.
Nev.
26th Oct 2021, 11:50 PM #3
Hi Nev, Guys,
Unless you tie the four supporting legs together they will move apart, particularly in a sandy soil. You also have to take into account that over time one leg will move/sink more than the others.
Lots of buildings are on stilts/legs but generally go down much more than 0.6 metres, usually to the solid surface below, but a lot depends on how the water affects the soil and building weight.Best Regards:
Garden edge
By Snapey in forum TIPS, TRICKS & HOW TO'SReplies: 9Last Post: 24th Apr 2020, 02:25 PM -
Putting a Whirlybird on a Garden shed
By bwal74 in forum METALWORK GENERALReplies: 7Last Post: 9th Jul 2016, 11:55 PM -
New shed. Buy or build
By Steamwhisperer in forum METALWORK GENERALReplies: 99Last Post: 9th Jul 2015, 08:50 AM -
Spiders in the Garden
By DSEL74 in forum THE SMITHYReplies: 1Last Post: 18th Jun 2015, 12:45 AM -
Garden Arbor
By yaryetnom in forum METALWORK GENERALReplies: 13Last Post: 17th Oct 2008, 11:35 PM
