Results 1 to 2 of 2
Thread: Bluing/blackening steel - rust
15th Jul 2021, 03:49 AM #1New Member
- Jul 2021
- Austin
- 1
I’ve been trying to use Jax iron, steel, and nickel blackener on some steel door pulls I made. I cut grooves into the metal with a 1/4” thick cutoff wheel and brushed Jax into the grooves them sanded the surface so just the grooves would be black. Problem is the blackener just rusts in the grooves instead of turning them black. I wiped everything down with mineral spirits prior and used gloves to avoid skin oils but it doesn’t make a difference. Does anyone know why this is happening?
16th Jul 2021, 10:10 PM #2Senior Member
- Oct 2015
- melbourne
- 473
Maybe the steel dust from the sanding is affecting the process? Let it all blacken and then polish the high spots.
Rust removal from steel shelves
By samuelthomson in forum METALWORK PROJECTSReplies: 5Last Post: 26th Jul 2021, 11:00 AM -
My second attempt at steel bluing
By BobL in forum METALWORK GENERALReplies: 20Last Post: 4th Dec 2018, 02:25 PM -
Oil Blackening Steel
By jack620 in forum METALWORK GENERALReplies: 11Last Post: 4th Nov 2012, 02:15 PM -
Rust proofing steel lintels
By Gotta Plan in forum METALWORK GENERALReplies: 7Last Post: 1st Aug 2011, 11:56 PM
