Results 1 to 6 of 6
Thread: Hot water service lifespan
14th Jun 2021, 12:46 PM #1Most Valued Member
- 2,651
Just replaced our old Rheem electric HWS.
It was in the house when we bought it, still working ok but I was pretty sure it was running on borrowed time. With #1 daughter and her mob moving back in for a extended period I didn’t want to get caught out with it dying at an inconvenient time.
Looking at when it was born which as far as we can tell is related to the serial number - I think it’s done pretty well
14th Jun 2021, 01:13 PM #2Most Valued Member
- 2,651
It’s also damn heavy - not surprising given the steel thickness
Compared to the modern (10yo) unit that I’ve used for my furnace build.
14th Jun 2021, 01:22 PM #3
I turned my 400L Dux (approx 18 years old) into an offset smoker. Can confirm approx 3mm.
I did have some thermostat issues which led to some wiring damage, which was repaired degraded to the point of (electric) failure. Swapped out with instantaneous gas job as part of a remodel.
That being said, a new thermostat and element would have seen it live a much longer life I think- they are not too complicated- total loss would be a result of rust or sludge build up. FYI if you peek inside one, don't drink the hot water
14th Jun 2021, 05:10 PM #4
Hi Steve, Guys,
Mine is a similar hot water system ! 150 Ltr very thin, 1.5 mm wall stainless steel tank surrounded by a thick foam jacket inside a cardboard tube. Its a high water pressure system, max 5 bar, with an air bladder cylinder at the top, the whole lot inside a welded plastic covered steel tube, with a plastic base and lid.
Its just a little over 14 years old. I recently had to replace the air tank because it sprung an air leak and water came out through the rusted metal of the air tank. Even though the main tank is stainless steel with a 25 year guarantee the air tank is mild steel and not covered. The new air tank is warranted for only ten years.
The French very commonly use this kind of high water pressure system usually electrically heated but some use gas or in some cases both.
Originally the hot water system was a nice simple 40 gallon plastic tank in the roof space. I live in a bungalow, the downside of having 40 gallons of cold water in the loft is that it creaks when the temperature changes and the shower was very poor because of the four foot of head. So fitting a hot water mains pressure system improved the shower performance tremendously.Best Regards:
14th Jun 2021, 06:38 PM #5Most Valued Member
- 70
- 1,511
I little tip about how water systems. If you need a water meter replaced then turn off the water supply to the HWS and then disconnect and flush the pipes to the HWS after the work is completed. Otherwise you may end up with a HWS full of mud. Happened to me.
Nev.
16th Jun 2021, 11:23 PM #6Senior Member
- Oct 2015
- melbourne
- 473
So you suggesting my 53yo hws could be approaching end of life? I have replaced the elements once. Or is it twice?
Good service.
By bollie7 in forum GENERAL DISCUSSION / OFF TOPICReplies: 1Last Post: 11th Oct 2020, 06:22 PM -
Getting the DSG into service
By caskwarrior in forum METALWORK PROJECTSReplies: 3Last Post: 18th Sep 2018, 10:31 AM -
Great service
By Big Shed in forum METALWORK GENERALReplies: 1Last Post: 30th Aug 2011, 06:14 PM -
Service records
By neksmerj in forum METALWORK GENERALReplies: 6Last Post: 25th Apr 2011, 09:05 PM -
Service Manual?
By mob in forum THE HERCUS AREAReplies: 1Last Post: 5th Oct 2008, 05:30 PM
