Continue using Fusion 360
Subscribe to Fusion 360 and save 30% today.
Hi Bob,
Your Fusion 360 for personal use is scheduled to expire soon. We'd like to offer you 30% off an annual subscription to Fusion 360.
Why subscribe?
With a Fusion 360 subscription, you'll get access to:
  • Unlimited active and editable documents
  • Export file types, including IGES, SAT, DXF, and DWG
  • Automatic tool change, multi-axis machining, rapid movements, and more
  • Multi-sheet drawings and templates
  • Simulation and generative design capabilities
  • Multi-user data management and team collaboration
  • Phone and
  • email technical support
Should you still qualify and wish to continue with Fusion 360 for personal use, you'll need to renew by following these steps once your current term expires.
Let me know if there is anything I can do to assist.
Shannon McGarry
Community Marketing Manager
[email protected]
To renew a free personal license for Fusion 360:
Note: You cannot renew a Personal Use license until the current one has fully expired. To check the expiration date, check About dialog from the Help menu in Fusion 360.
  1. Go to the Fusion 360 for Personal Use home page.
  2. Scroll down the webpage to the Activate Fusion 360 for personal use section.
  3. Select Get Started
  1. Select Sign in to your Autodesk Account. If you don't have an Autodesk Account, select Create Now.
  2. After you sign in, select Download Fusion 360 for personal use.
Note: Even though Fusion 360 may be installed, you must select Download Fusion 360 for personal use to complete the registration process. It may take up to 30 minutes for your new subscription type to update. Please allow at least 30 minutes before signing into Fusion 360.
Merry Christmas to all,Bob
