Results 1 to 15 of 15
Thread: Elvington Air Museum !
10th Sep 2020, 05:50 PM #1
It was a beautiful day here in North Yorkshire, UK, yesterday ! So my wife and I decided to visit the Air Museum near York. It is an old WW2 RAF bomber command base. The French also had squadrons of pilots here.
One of the very famous aircraft that is still flying is housed here, the "Lancaster Bomber", fully refurbished in its original livery. This aircraft carried the enormous "Grand Slam" and "Tall Boy" bombs apart from the famous "Bouncing Bomb" so successfully used in the "Dam Busters" raid.
One of the things that struck me was the tiny "Browning 303" machine guns carried in the turrets ! Tiny compared to the 20 mm cannon fitted to the later "Spitfire" and "Hurricane" fighters. Its no wonder that they had a hard time defending against the German 109's that already had 20 and 30 mm cannon.
Halifax Bomber ! I've spoken to a guy at Elvington. He has confirmed that this aircraft is not a Lancaster Bomber.
Thanks to the eagle eyed among you.
Tall Boy bomb.
German 109 fighter.Best Regards:
10th Sep 2020, 06:08 PM #2Senior Member
- Perth, Western Australia
- 67
- 362
No pics or is it just me.
Tony
10th Sep 2020, 06:13 PM #3
10th Sep 2020, 06:52 PM #4Senior Member
- 67
- 362
Thanks BaronJ
I don`t think that's a Lancaster. Lanc`s had Rolls Royce Merlins not the radials on this one. Its name escapes me at the moment but it was designed by the same guy that designed the bouncing bomb.
Love the ME 109.
Tony
10th Sep 2020, 07:06 PM #5I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,300
Looks like a Handley Page Halifax?
But I don't think Barnes Wallis was involved, I think he was on the Vickers Wellington? Could well be wrong.
*EDIT*
For what it's worth, there is currently one airworthy Lanc in the UK, based out of RAF Coningsby. From memory known as "City of Leeds". There is also "Just Jane", who has been used for taxi rides for some years at Lincolnshire Aviation Heritage Centre, and which has been undergoing restoration works in the off season, with a ten year plan to getting her airworthy again. Some interesting videos on YouTube from that process, gives you a great look at how they were put together, and how involved restoring one is. Guy called Neville Wheeldon posts a lot of videos of the process.
Wikipedia tells me there are also two on static display in the UK, one in London and one at Duxford, although of course that is not necessarily an extensive list.
The only other airworthy Lanc in the world at this time is based in Canada, powered with the Packard version of the Merlins IIRC.
10th Sep 2020, 07:07 PM #6Senior Member
- Feb 2014
- Werribee, Melbourne
- 178
Tony, there was one version of the Lancaster that had Bristol Hercules radial engines - I would think this one is a pretty rare bird.
I saw a picture on the 'net some time ago and went digging as I thought exactly the same thing.
10th Sep 2020, 07:22 PM #7
Some Lanc's had radials as the Merlin production and supply was always tight with Spits, Hurricanes, Lancs and Mosquitos in high demand. I am not aware that any radial Lancs were used for the Dambusters or Tallboy raids, but wouldn't rule out the possibility. The plane you are thinking about (radial engines, designed by the man behind the bouncing bomb) was the Wellington bomber, a twin engine machine designed by Barnes Wallace. A fairly tough high survivablity aircraft at the start of the war because it was framed in a geodesic arrangement of rolled ali members and fabric covered. Unless the Germans hit an engine, oil tank etc or crew, their bullets or shells basically went straight through the aircraft and out again, generally causing minimum damage to the airframe. Quite often could be patched and ready to go within an hour or so, by riveting in a replacement section of ali and doping on a cloth patch to cover the holes.
10th Sep 2020, 08:31 PM #8Senior Member
- Oct 2009
- Upwey VIC
- 187
Definately a Halifax...radial engines, squarish shaped vertical fins, closed rear to the cockpit.
10th Sep 2020, 08:52 PM #9
Some very interesting information there. The picture of the aircraft that I posted is labelled as a "Lancaster" but until it was pointed out, I hadn't noticed the radial engines. There is a partially disassembled RR Merlin engine near the aircraft.
There are a number of foreign aircraft at the Museum including a number of reproductions of historic ones.
Some more pictures
As you can see from this picture, it was a brilliant day.
A Vampire jet.
I don't think anyone could mistake a VTOL Harrier.
Some of the other aircraft hanging from the roof.
A RR Derwent jet engine.Best Regards:
10th Sep 2020, 09:06 PM #10I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,300
Rather disappointing if the museum can't get that right....
In addition to the things mahgnia mentioned, the front blister on that one is different compared to the Lancs double blister (don't know if the Lancs ever had anything different, although later Halifaxes seem to have gained a similar arrangement), and the landing gear is completely different (much more solid looking on the Halifax)...
I, of course, have a soft spot for the Lanc as my grandfather lied about his age in order to go and do two tours as a navigator on them.
Still nice to see the Halifax though, we tend to forget that they were still in operation right through to the end, overshadowed as they were by the Lancs.
10th Sep 2020, 09:54 PM #11Senior Member
- Feb 2014
- 178
Tony, my apologies - you were absolutely correct in picking that it wasn't a Lancaster as pointed out by the more eagle eyed chaps above.
There were Lancs with radial engines but I didn't look beyond the engines when I replied above.
There is a pretty big clue in the address of the Museum
Address: Halifax Way, Elvington, York YO41 4AU, United Kingdom
This Halifax is a bit if a 'bitsa' - interesting write-up here https://yorkshireairmuseum.org/exhib...e-halifax-iii/
11th Sep 2020, 07:22 AM #12
Mistaken Identity !
I've been back to my original post and corrected the information.
After checking I can confirm that the aircraft is in fact a rebuilt Halifax Bomber.
Barns Wallis.Best Regards:
11th Sep 2020, 06:00 PM #13
surviving
Apparently the Halifax crews had a higher survival rate compared to the Lancaster . The Halifax had easier ways to escape the aircraft , the escape hatches were easier to get at in an emergency. Some pilots preferred the later Mks of the Hali to the Lancaster because it was a slightly faster aircraft . A friend of mine in town here, his dad was a Stirling pilot in a Special ops squadron 299, Jim flew SOE agents over to Norway and towed gliders over to Market garden , Jim left school at 14 and did a apprentiship as a slaughterman at the local abbatoir. I have copies of Jims pics
12th Sep 2020, 12:48 AM #14Senior Member
- 67
- 362
Wellington was the one I was thinking about in my first post. Could not be more wrong. 4 engines, a different tale and nose. I think I just sore radials then had a brain fart.
Never new Lanc`s had radials. Live and learn.
Anyway good to see a museum still open.
Tony
12th Sep 2020, 01:32 AM #15
Hi Tony,
Yes, it is ! They are having a hard time at the moment, with our "Boris" messing things about. They have only just re-opened the NAFI only to have to close it again. So they have set up an outside shop for pre-made food. The nice thing is that they have extended our annual pass to the end of November because of the local lock down. But at £9 each its hardly going to break the bank !
I'll take some more pictures next time that we go there. They have an awful lot going on !Best Regards:
Campbelltown Steam Museum
By wheelinround in forum GENERAL DISCUSSION / OFF TOPICReplies: 0Last Post: 26th Oct 2019, 09:56 AM -
Deutsches Museum - Munich
By kwijibo99 in forum ANTIQUE AND VINTAGE MACHINERYReplies: 12Last Post: 20th Jul 2019, 01:09 AM -
Black Country Museum !
By BaronJ in forum ELECTRICALSReplies: 2Last Post: 14th Aug 2018, 07:43 AM -
Bradford Industrial Museum.
By BaronJ in forum METALWORK GENERALReplies: 24Last Post: 26th Feb 2018, 08:06 AM
