Results 1 to 9 of 9
    Oct 2018
    Dandenong
    13
    Default Otto Benz blow lamp
    Put this on thw WWF then thought this might be better.
    "Not sure were to ask this question, but I have a Otto Benz blowlamp (old)
    and have been trying to find what fuel to use. I've tried kero but it doesn't get up
    to a proper flame. A lot of info on the net says petrol (gasoline as they say over there)
    Now I'm a bit of a coward so want to know if anyone has any knowledge of
    these lamps.
    I remember as a wee fella (many moons ago) Mum had an iron heated by petrol
    so they must have used petrol in some things, and these lamps seem reasonably
    common in the USA.
    The company of old Otto became Benzomatic.
    Would put up a photo if I knew how to get it off the phone.
    Any info would be appreciated,
    Robb41"
    ps I'm Robbo37 on the WWF
    Mar 2009
    54
    825
    G'day Robb,
    I would have thought kero would be fine but another option would be shellite.
    Fuel options with these is set by the size of the jet, petrol versions have much smaller jets so you need to be a bit careful or you'll end up with a fireball.
    Are you getting the vaporizer tube hot enough before you turn the fuel on?
    A tip with these is pre-heat the vaporizer tube with metho rather than kero which avoids the buildup of carbon and keeps them cleaner.
    Greg.
    Oct 2018
    Dandenong
    13
    Quote Originally Posted by kwijibo99 View Post
    G'day Robb,
    Greg.
    Thanks Greg,
    I use metho for heating, but will try more heat and check out the jet size. It is quite a beast.
    Oct 2008
    Cairns, Q
    666
    Does it have a cup below the vaporiser for metho to burn and preheat the vaporiser? If not it was probably designed to run on Shellite as Greg suggested. Back in the day Shellite was commonly used in petrol irons, petrol pressure lamps and stoves. I was surprised to see that it is still available:
    https://www.bunnings.com.au/diggers-...E&gclsrc=aw.ds
    Frank.
    Oct 2018
    Dandenong
    13
    Quote Originally Posted by franco View Post
    Frank.
    Yes Frank it does have the cup for pre heating so I'll give the kero more time.
    Oct 2007
    Alexandra Vic
    69
    654
    I still have a couple of my father's Tilley blowlamps that were in use through my childhood and teen years. Primary fuel was Kerosene, and they have the cup under the vaporiser for preheating. The cup is filled with metho and lit. The metho should burn for a couple of minutes, heating the vaporiser. The kero tank is pressurised before the metho is placed in the cup and lit, and when the metho is about exhausted, the control valve is opened and the kero vapor flows and is ignited by the metho flame, and the control valve is adjusted to suit the task.
    Always allow the burner to fully cool before replenishing the kero or metho to relight, there is a danger of explosion if metho meets a hot burner.
    Oct 2018
    Dandenong
    13
    Quote Originally Posted by malb View Post
    Thanks, I have a couple of the Sievert kero blowlamps but from what I can glean from the WWW these use petrol.
    Someone else said to try Shellite and that is basically petrol before all the additives are put in, same flashpoint etc.
    Having worked in the oil industry for quite a few years, I'm pretty wary of the stuff.
    Oct 2018
    Dandenong
    13
    Default Otto Bernz Blowlamp
    I bit the bullet and took the lamp outside, put some petrol in (extinguisher at hand) and warmed it up
    with metho then slowly brought in the petrol....all good with a nice blue flame.
    Can't work out how to attach a video, sorry.
    Jul 2006
    Athelstone, SA 5076
    4,258
    dad just used kero. He put a small piece of rag in the cup and filled with kero..this got the temperature up to get the kero warm enough so that atomized fully when leaving the jet.
    I used Shellite in my camping lanterns and cooker as it burned cleaner
  1. Primus lamp wick feeder pinion
    By Steamwhisperer in forum METALWORK PROJECTS
    Last Post: 8th Jul 2018, 12:21 AM
  2. CQ6230A work lamp question
    By Ron Hall in forum METALWORK GENERAL
    Last Post: 2nd Apr 2014, 06:42 PM
  3. An attempt at improving a H and F Lamp.
    Last Post: 11th Jul 2011, 11:01 PM
  4. H and F Halogen Lamp
    Last Post: 25th Dec 2010, 09:35 PM
  5. Project Lamp
    By ro4441 in forum METALWORK GENERAL
    Last Post: 6th May 2009, 07:36 PM
