Results 1 to 15 of 15
Thread: Silex no66 marking gage
13th Jul 2020, 03:49 PM #1Most Valued Member
- 4,255
Does anyone have a Silex No 66 dual marking gage.
I am trying to figure out what holds the front marker, and how the 2nd is held stationary when it use.
13th Jul 2020, 07:43 PM #2
Hi Richard, Guys,
Looks quite crude ! I would think that the scribes are just pressed into place.
I made one some time ago and find it quite useful for some jobs. Though laziness often means I just use the digital vernier to scribe a line.
Family picture.
The scriber is a 3 mm broken carbide PCB drill. Un sharpened at the time this picture was taken.
I used a screw in the end to clamp the scriber.Best Regards:
13th Jul 2020, 07:49 PM #3Philomath in training
- 6,541
Not much help, but it looks like the outer is held with the thumb screw and the inner is adjusted via screw and locking nut. I suspect the scribers are a push fit into the split ends.
13th Jul 2020, 08:36 PM #4Most Valued Member
- 4,255
Inherited from my dad a tinsmith.
it has always had one scribe but is obviously made for two as the pic the Michael has posted. Its just that I cant fathom why the first scribe only goes thru a hole at the tip while under it passes tbru the slot. ...and what stops the slide from moving once its set as the adjusting mech at the end pulls off. Wonder if its meant to be a tight but removable fit?. ???.
If I cant figure it out I will just return it to a single marking gage.
13th Jul 2020, 08:41 PM #5Most Valued Member
- 4,255
Yeah i s aw that also Michael it doesnt tell me why the 1st scribe goes into a hole in the top of outer arm but passes thru the slot in the bottom? Would have thought it should have a support at bottom as well. The scribe in slide is also a tight fit ie removable for sharpening/replacement etc.
13th Jul 2020, 09:54 PM #6
Hi Richard, Guys,
Could it be that the back of the scriber runs in the groove so that both scriber’s are kept in line for marking two parallel lines.
When you mentioned "Tin Smith" it occurred to me that marking a parallel line is what you would do for a fold.Best Regards:
13th Jul 2020, 10:11 PM #7Philomath in training
- 6,541
Not sure I understand the question that you are asking. Attached is a sketch of how I think something like this should be arranged (the threaded part of the inner slide may be separate from the scribing part...). The inner can be moved and locked in postion with respect to the outer, and the outer scriber can be moved with respect to the external stop.
Based on your photos, it looks like you have most of the parts - although I'm not sure that all of the parts are original or are not without damage.
14th Jul 2020, 11:19 AM #8Most Valued Member
- 4,255
Only part it is missing is one scribe.
Maybe these pics spell it out a bit better?
Top of frame.jpg under frame.jpg.
as for the thngymebob at the and..on mine it pulls off...I am guessing mine is a tad worn in that rea and is cause of it coming off easily
14th Jul 2020, 08:07 PM #9Philomath in training
- 6,541
The thngymebob at the end should be fixed on the outer tube. That is how the inner and outer maintain fixed relative positioning. A bit of bearing locker would do it if the push fit is a bit ropey.
Seeing the slots I think that gauge has been mis-treated sometime in the past - perhaps someone trying to get it apart or trying to get some extra range out of it. The hole in the outer should be 'whole'. Should the end be plugged to provide a hole for the scriber? Can't tell if there is a plug there already but there looks to be a groove around the top that suggests something in the end of the outer may have been secured with a crush fit. Alternately (or maybe as well) a dot of weld to close off the hole may be needed. If you haven't got a TIG I could manage that for you if you want to drop around.
15th Jul 2020, 10:09 AM #10Most Valued Member
- 4,255
16th Jul 2020, 02:42 AM #11Senior Member
- Nov 2010
- Frankston south
- 102
Here are some pictures of the timber workers version....IMG_0818.jpgIMG_0817.jpg
19th Jul 2020, 07:45 PM #12
Hi Eskimo,
I have a Silex No.90
It also is a dual.The scriber pins are indeed a friction fit.Mine has twin knurled head screws - one for each shaft.
The shafts each have a flat for the screws and both run about 7.80 mm diameter and the split is .94mm wide.
Engraved markings are in imperial. The registration face is recessed for both shaft scriber pins to recess into it.
Have you checked the shaft diameters each way. Possibly the shaft locks with a cam action.
hope it helps
20th Jul 2020, 04:39 PM #13Golden Member
- Cairns, Q
- 666
Hi Eskimo.
I have a No.66 bought new years ago. As far as I know the No 66 was only ever supplied with a single scriber. I have often been wrong before though,
as my wife frequently tells me. Mine has a single solid 5/16" diameter six inches long scriber arm with a flat for the clamp screw to bear on. At 90 degrees from the flat there is an adjustment scale with 1/16" divisions. The scriber point is inset 1/16" from the end. I wonder if your No. 66 has been modified to take the dual scriber assembly from another gauge - possibly from a Silex No. 98 or similar?
Michael's photo shows a No. 98 with the dual coaxial scribers. The boss on my No. 66 casting for the scriber hole has an O/D of 3/4 " . The No. 98 gauge in Michael's photo appears to be larger then the 66 overall, and the outside scriber arm appears to be well over 5/16" diameter, which wouldn't leave much meat in the boss on the No. 66 casting if it was bored to suit......Interesting.
FWIW I made a separate arm for mine which carries a pencil instead of the scriber point. This sees much more use than the scriber point.
Frank.
21st Jul 2020, 06:05 PM #14Most Valued Member
- 4,255
Got the 90 also Grahame
21st Jul 2020, 06:16 PM #15Most Valued Member
- 4,255
[QUOTE=franco;1971732]Hi Eskimo.
Frank.[/
Hi Frank
Micheals pic shows the same as mine as it has the adjuster at the end which slides the internal shaft inside the outer.
Had a closer look at mine and it has two no's...No60ty something on the right....the last digit appears to be iether 6 or possibly 8 partially obscured by a a tinsmiths rivet...why Dad?...why does it have four rivets
The left side has No98. So I give up...how can it have 2 model numbers.?
Marking Gauge.
By BaronJ in forum METALWORK GENERALReplies: 12Last Post: 8th Jan 2018, 02:47 PM -
Random Questions about Gage Blocks
By RayG in forum METALWORK GENERALReplies: 19Last Post: 6th Mar 2013, 06:08 PM -
Shaper gage ( sic )
By morrisman in forum METALWORK GENERALReplies: 3Last Post: 11th Jan 2013, 10:12 PM -
Marking Fluid
By grunto in forum METALWORK GENERALReplies: 81Last Post: 28th Aug 2012, 12:12 AM -
Marking out hollow bar
By Bidgee in forum METALWORK GENERALReplies: 13Last Post: 27th Oct 2011, 11:30 PM
