Results 16 to 25 of 25
20th Jan 2020, 08:26 PM #16Member: Blue and white apron brigade
- 7,183
It depends a bit on the drill. My newish Makita cordless hammer drill does a really good job through bricks and concrete so I stopped using my 240V gear for these sorts of jobs. The Old 240V Ozito has an SDS chuck so I use that for longer holes in concrete as I have a set of long bits for it.
20th Jan 2020, 08:31 PM #17
Batteries are available from Chinese sources, and its not too hard to rebuild a battery pack ! The problem is that you really need a spot welder to weld the replacement nickel strips connecting the batteries to each other.Best Regards:
24th Jan 2020, 09:41 AM #18Most Valued Member
- 4,255
24th Jan 2020, 08:44 PM #19Most Valued Member
- Charlestown NSW
- 1,669
haha, I have no idea actually. Some numbers have just stuck in my head yet others either disappear entirely in a short space of time or worse, transpose into a different number. Usually only discovered after I have cut, made or ordered something to the wrong size. Case in point. I recently ordered a cheap coolant pump from Aliexpress. Some time between measuring my tank at 210mm deep and ordering the pump, I managed to transpose the numbers and turn it into 120 mm deep. Duh. So the pump arrived today and its way to short for my tank. bugger.
No but I can remember it was $45/week on top. I thought I was rich.
peter
24th Jan 2020, 09:45 PM #20Most Valued Member
- 5,945
I can remember my first pay packet, $12.60 after tax. I can remember my bank details from 20+ years ago, but have trouble lately with passwords, so I write them down.
Only trouble is trying to remember where I placed the book with them in!!!!!!To grow old is mandatory, growing up is optional.
24th Jan 2020, 09:51 PM #21Member: Blue and white apron brigade
- 7,183
I remember my first pay packet. I was 13 and mum dragged me around the shops in a small country town and signed me up for a job during the school holidays at a small menswear store. I had to dress like a dork in all new clothes, dress shorts, collared shirts, tie, and new school type black shoes, which I had to pay for by borrowing money from mum. My pay was $10.30 a week and it took me more than half the holidays to pay off the cost of the clothes. I spend the rest of may pay on a Joplin Vice which I still have and a set of P&N drill bits some of which I still have.
Apart from the shoes, which I subsequently wore to school, I hated those clothes and avoided wearing them as much as I could. Before the next summer holidays I got myself a job stacking supermarket shelves in the evenings and could wear regular jeans and sneakers. Mum was very disappointed I was not wearing nicer clothes to work. Can't remember what it was but the pay was lightly better, plus we could eat as much of the left over doughnuts and other baked goods that were being thrown out at the end of the day. I reckon I put on about 10lbs that summer. There was a group of 4 other lads involved in the cleaning up and restocking and we got up to all sorts of mischief those evenings.
The following summer I decided to get a real job in a cement product concrete factory. Excellent pay but- hot - dusty - grimy - backbreaking stuff. I could go on but that's enough for now.
26th Jan 2020, 09:35 PM #22Senior Member
- Jun 2016
- 283
I have a 40 yr old B&D corded drill with cast aluminium body and 2 speeds (by gears). Made before they went plastic. I have a smaller Makita corded drill as well. Both get used extensively on the farm and in the workshop. I don't have a battery-powered drill. Thought about it a few times, but never really needed one.
Btw: a brace & bit with a flat drill bit will go through timber faster than an electric drill ime. I have 3 braces.
Roger
26th Jan 2020, 11:06 PM #23Member: Blue and white apron brigade
- 7,183
Have you tried the Speed Bore Augers on an electric?
My problem using braces is I run out puff/speed after a couple of long holes.
I used a brace for about half a day when I started building nature playgrounds (often whole hardwood logs and branches) but gave it away for a set of speed bore bits, a gutsy cordless drill, an even gutsier cordless impact driver, and 4 batteries.
Most days two batteries (one on the drill and one on the driver) were enough to drill many dozens of holes and drive in the up to 20 mm diam x 300 mm long coach bolts. The driver was able to drive in the 12 x 150 mm long coach bolts without drilling holes except that it would occasionally snap the heads off about 1/2 - 3/4 of the way in. When I drilled the first few holes holes for the 20 mm diameter coach bolts some were too short and found if I was not careful the driver would snap the heads off those coach bolts when they bottomed out.
This was a set of stairs cut from two lengths of 650 mm diameter Spotted gun, and bolted together using 20 x 300 mm coach bolts.
The bolt heads are recessed 50 mm into the timber surface and the holes filled with a piece of dowel turned from PUECE OF THE HOLE
These were some of the tortoises in the nature playground I did carved the heads legs and tails for.
The biggest one is ~8m long and just the head/nech alone weighs about 600kg.
To support the heads, legs and tails above the ground I fabbed up steel stirrups from 3 x 50 x 50 SHS and bolted these to the undersides of the appendages using 12 x 150mm coach bolts.
These logs were used as ladder/steps at an angle of about 15-20º and sat in recesses cut into another log and pinned in place with large coach bolts
FWIW the carving of the turtles was performed initially with a 72cc and then with a 35cc chainsaw with a dedicated carving bar. The carving detail was done with a TC tipped 100 mm Arbortech carving wheel on a 240V 100mm Makita angle grinder which I ran from a genset, as my cordless grinder chewed very quickly through batteries. The
Because I already had the genset on site I could have drilled the holes with a 240V drill but I don't like dragging power cords all over a site and repeatedly starting, running and stopping the genset.
The big stairs were cut with custom made 120cc chainsaw mill.
27th Jan 2020, 06:54 AM #24Senior Member
- Jun 2016
- 283
Speedbores
Speedbores - yeah, that's them. I especially like the version with the little pointy tips out at the corners.
My B&D with 2 gears runs at 900 RPM on low gear: and goes through almost anything.
Must say, I like those steps (1st photo). They look beautiful. Have you treated the wood with anything? I ask because I have a 20 L drum of linseed oil I got for very little, and I find it is wonderful stuff. All wooden tool handles get it.
Carving bars for a chainsaw? Tell me more, please. I have 3 petrol chainsaws of various sizes, and one 2.4 kW electric chainsaw. And some l o n g extension leads. I find the electric chainsaw the most useful of the lot, and MUCH safer.
Roger
27th Jan 2020, 09:35 AM #25Member: Blue and white apron brigade
- 7,183
Linseed oil and turps mix, 3 coats. Of course they finish only lasted in the open for a few months and with no one paid to re-coat they eventually went the usual grey.
The carving bar runs a 1/4" pitch, micro chain, is about 12" long, and the tip has a radius of curvature similar to that of a 20c piece.
These bars are not cheap but small size makes the bar a bit lighter and hence easier to operate, and the pointier tip makes it easier to cut detail.
The bigger saw runs a 3/8 Lopro chain which gives it a narrower kerf so less wood is removed but it also takes load off the power head. When I say the chain is a 3/8 chain, it's not really 3/8 and it requires a special drive sprocket not readily available so I make mine from 0.404" rim sprockets. The metal used in rim sprockets is some form of sintered/hardened steel alloy that challenges even carbide bits on the lathe.
Re purposing a pot as a wire wheel guard
By bollie7 in forum METALWORK PROJECTSReplies: 9Last Post: 22nd May 2019, 10:05 AM -
240v electric motor
By Turbine Builder in forum METALWORK - Machinery, Equipment, MARKETReplies: 7Last Post: 4th Sep 2018, 10:01 AM -
best way to run 3 phase stuff on 240v ?
By thorens in forum METALWORK GENERALReplies: 20Last Post: 14th Sep 2011, 07:20 PM -
Which 240V Mig Welder to Buy?
By Ticky in forum WELDINGReplies: 20Last Post: 23rd Jan 2008, 08:01 PM
