Results 1 to 5 of 5
2nd Dec 2019, 09:02 PM #1Most Valued Member
- Charlestown NSW
- 1,669
Different names for the same thing in metal working
I was txting Dave J today and during our conversation we got around to different names for the same things in engineering.
Example - Threaded bar. I know at least 4 names for it. When I worked in the power station back in the 1980's we called it Studbar. Some of the old hands who had worked there during construction called it Brooker bar. Others call it Thread bar or All thread.
Baron J - what do you call it in the UK?
Any other things or processes with different names? I'm just curious
peter
2nd Dec 2019, 11:48 PM #2Most Valued Member
- 5,942
Bright bar which some people call shafting and another is drill rod, it's also called something else that I can't think of ATM.
3rd Dec 2019, 04:49 AM #3
Slot drill? No, 2 flute end mill.
3rd Dec 2019, 06:41 AM #4Philomath in training
- 6,541
3rd Dec 2019, 07:20 AM #5
Hi Peter, Guys,
Pretty much the same, though "Brooker Bar" is a new one !
Drill Rod, silver steel rod or ground rod covers that one. Gauge Plate, ground bar or ground plate is another.
Though "Bright Bar" usually means rolled bright steel and Black Bar rolled steel which still has the mill scale on it. Either could be round or flat, though over 300mm wide is usually referred to as plate.Best Regards:
Working with galvanized metal
By bbqjoe in forum METALWORK GENERALReplies: 16Last Post: 14th Feb 2017, 12:39 AM -
How do I make one of these (long thin metal thing)
By Arron in forum METALWORK GENERALReplies: 17Last Post: 7th Sep 2013, 04:31 PM -
Metal Working Bench
By 355tonner in forum METALWORK GENERALReplies: 23Last Post: 13th Nov 2011, 09:08 AM -
Metal Working For Woodworkers
By echnidna in forum METALWORK GENERALReplies: 0Last Post: 26th Apr 2009, 04:09 PM -
Metal working links.
By RETIRED in forum METALWORK GENERALReplies: 1Last Post: 17th Mar 2009, 06:40 PM
