Results 1 to 7 of 7
    Oct 2010
    NSW
    181
    Default Another what am I
    Obviously fits in a square tapered hole - swage block/anvil - but for what? Not robust enough for heavy work - sheet metal maybe? Not obvious in the photos but the 'horn' is only about 4mm thick.
    Sorry about the dodgy phone pics.
    TIA
    John
    Jun 2016
    Sydney
    283
    Red face Weapon
    Stick a wooden handle on it, polish, sharpen the edges and tip, proceed to the nearest battle field. Scary!
    Roger
    Oct 2009
    Upwey VIC
    187
    Jeweller's ring sizer?
    Oct 2015
    melbourne
    473
    Blowhorn stake
    Sheet metal work
    https://www.google.com/search?q=blow...=UTF-8#imgrc=y
    Russ
    Oct 2010
    NSW
    181
    Quote Originally Posted by russ57 View Post
    Blowhorn stake
    Sheet metal work
    Russ
    BINGO.
    Thanks Russ, that was quick. Now I don't know why I didn't ask you lot before searching.
    John
    Oct 2007
    Alexandra Vic
    69
    654
    Noticed that you had answered your own question when reading the first post, for sheet metal (tinsmith) work, typically long tapered circular sections like the spout of a funnel, where the seam needs to be supported internally while it is being closed.
    7,188
    malb's on the money. Saw a tin smith using one to make a watering can spout at a lost trades fair in Canada. He had a smaller one that he used to make funnels, teapot and oil can spouts. Very cool.
