Results 1 to 15 of 15
    Aug 2006
    1,106
    Default How to dispose of old Gas Cylinder Safely?
    Well I have a bunch of old propane cylinders, most over 20 years old so guessing would need some sort of inspection if they need to be used again (probably not worth it). Was just wondering how I could dispose of them safely, is there a place that I can take them to? They range from 9kg bbq bottles, 2kg bbq bottles and some of those primus cylinders.
    Jan 2004
    Mackay North Qld
    6,446
    HI VC,
    Just invert them and open the valve and drain them this way, out the gas because it is heavier than air.
    My local recycle place take them this way as I have puchased the scrapped cylinders from them.
    You could make a "choofer" a a caravaners wood fired camper stove.
    if so
    Remove the valve by heating up the brass valve with a NON FLAME source- heat a lump of steel a hot as you can get it, and set it on the valve. Remember NO FLAME.
    If you have made a "key" -just a couple of lumps of flat welded to accommodate the valve and grip it.Weld on a length of pipe and a tee handle.
    Of course you need to have it secured to a fencepost or the like so it won't rotate as you unscrew the valve. I like the cylinders with slots in the base ring for this reason.
    It should then unscrew as the valve is likely to have locktite or similar on the thread and very difficult to move cold.
    I have removed several valves this way.
    No welding or cutting until you put a cylinder of water through the cylinder in the upright position .If any gas at all and the water will displace it.
    They will still stink even after you fill them with water- the stink is from the mercaptan used to give the gas its recognizable odour
    Aug 2006
    1,106
    I thought of cutting them up, i'd probably want to leave the water in there though as I cut through it. Would use a pneumatic grinder.
    If the scrappy would take them for free i'd probably just give them to him.
    Jan 2004
    Mackay North Qld
    6,446
    I thought that may someone local might be in to making choofers. They might want one or all,
    7,189
    Our recycling centre will take ours.
    If you decide to cut one up as well as water I recommend adding a dash of detergent to help dissolve away the mercaptan oil.
    If the tank is corroded the mercaptan will soak into the corrosion and not come out with the water
    The mercaptan oil is flammable when it gets heated and although it won't explode it can generate a decent "WHOOOF" when you cut it.
    I emptied and then filled a 9kg bottle with water and detergent and changed the water and detergent mix every day for a week before I cut it and I still got a "whoof" out of it.
    This one turned out to have a fair bit of corrosion.
    Another cylinder I just filled with water once and emptied it and there was nothing, but it was not corroded inside
    Sep 2005
    Bendigo
    60
    419
    Check if your local collection point takes them first, last time I moved I had a number of cylinders and got hit with a charge for disposal of “pressure vessels”.
    Jan 2004
    Mackay North Qld
    6,446
    The recycle centre is where is obtained the ( out of date ) cylinders.
    It would not surprised if the centre is double dipping on cylinders .Get paid to accept and then charge the bloke who buys one .I paid $5 but drew the line on when they wanted $10. I could buy a new empty at the time for $30.
    6,480
    A few years back there was a serious gas cylinder explosion and a fatality with some people injured. The scrap yard involved was prosecuted and subsequently shut down, the local municipal council not only banned all scrap dealers from buying gas cylinders but also had the job of getting rid of the scrap yard's contents, some 1300 tons of it.
    near Rockhampton
    6,218
    Quote Originally Posted by Com_VC View Post
    I swapped a bottle 40 years since last inspection at a local swap and go place.
    Jul 2006
    Athelstone, SA 5076
    4,258
    You are obviously a lot older than me RC...mine were not that old but they were well out of date and i did swap them for bottles with gas also
    Jun 2016
    Sydney
    283
    Default Recycle!
    Cut them in hallf, paint them (hippie flowers etc), and sell them at a boot sale as flower pots.
    Roger
    Aug 2006
    1,106
    I was able to remove the valve without any heat, just secured it to the clothesline and used some leverage.
    Aug 2015
    QLD
    735
    If yer has a back yard and it is just to hard to otherwise dispose of the bottles, then - Take valves off bottles and bury them in the back yard..
    Jun 2016
    Sydney
    283
    Default simple enough
    Remove valve - it's brass and the scrap is valuable.
    Leave bottle in sun for a few days.
    Cut bottle in half - bandsaw, not oxy-torch for preference.
    Take steel scrap to scrap yard.
    If you must use a flame cutter, only do so after the valveless bottle has sat in the sun for a few days. Do NOT use a flame cutter without removing the valve first.
    Roger
  15. #15
    Jan 2004
    Mackay North Qld
    6,446
    Got grandkids or know someone with littlies.
    see Google for more variations.
  1. Safely melting silver
    By Danbre Macase in forum THE FOUNDRY
    Last Post: 6th Sep 2018, 12:58 PM
  2. How much can I safely lift on this structure?
    Last Post: 14th Sep 2013, 09:40 PM
  3. How to safely dismantle a gas shock absorber
    By simonl in forum METALWORK GENERAL
    Last Post: 20th Apr 2012, 04:23 PM
  4. Safely Weld a Car Tailgate?
    By abrogard in forum WELDING
    Last Post: 16th May 2011, 05:52 PM
  5. Just brazed up fuel tank-safely
    By Mathuranatha in forum WELDING
    Last Post: 8th Jun 2009, 09:43 PM
