Results 1 to 15 of 20
Thread: 50mm square elbows and tees
10th Feb 2023, 03:30 PM #1Member
- Dec 2015
- south coast, nsw
- 52
As the title suggests, I'm after some parts, being for a woodwork project. Can't find any on the net so I suppose they will need to be fabricated from square stock. Stainless would be nice but ally will do the job. Anyone interested or able to give recommendations?
10th Feb 2023, 07:58 PM #2
Hi Tiprat,
I don't know if it helps, but here in the UK Lidl are doing a whole range of metal brackets for wood jointing and the like ! Quite cheap in my opinion, $3.0 (New keyboard, no pound sign. read pounds)
Rubbish keyboard ! I took it back this morning and got my money back. I bought a new "SilverCrest" one at Lidl for £10.00. This one has a much nicer feel and has the magic "£" symbol.Best Regards:
10th Feb 2023, 10:32 PM #3Most Valued Member
Any chance of a sketch with some dimensions on it, please?
Otherwise it's like asking how long is the string.
Can look at doing them in Aluminium for you, once I've an idea of your request.
Kryn.To grow old is mandatory, growing up is optional.
11th Feb 2023, 06:41 AM #4Member
- Dec 2015
- south coast, nsw
- 52
12th Feb 2023, 04:50 AM #5Member
- Dec 2015
- south coast, nsw
- 52
12th Feb 2023, 12:08 PM #6Most Valued Member
I just realised where you're located, and postage / freight could be prohibitive.
If you could submit a sketch with details sizes etc, someone closer by may offer to help.
I don't have a scanner, but what I do, is take a pic of the sketch with my camera, download it then add it to the post/reply. I don't even have a mobile that has all the fancy stuff that they can do, just a plain old Nokia, and I have trouble using that!!!!
12th Feb 2023, 02:45 PM #7Member
- Dec 2015
- south coast, nsw
- 52
I took a pic on my old camera and discovered that the new computer does not have a slot to insert the card! So got my daughter to take a pic on her phone and email it to me so I could download it and then attach to this post. Anyway, I'll be in Burra hopefully from March and I don't think postage will be excessive. See what you think...
I don't know why the pic is sideways!
12th Feb 2023, 05:04 PM #8Most Valued Member
Thanks for the pic, so basically the pieces will be 100mm X 100mm over all size?
There are still a lot of questions remaining.
Will the metal need to be square on the edge, or can it be radiused?
What happens to them once you get them, will they be screwed/bolted through the wood into the tube, or from the tube into the wood. What is the thickness of the material, 1mm 1.6mm 5mm?
Will something be slid inside it, if anything, asking as the ends are left open?
What is the intended use of these pieces, to act as a spacer, or support a shelf?
Do the welds need to be ground back or can they be left as is?
How many of each piece is required?
What weight is anticipated to be supported?
The more information that we can get, makes it a lot easier for all, otherwise it's like pulling teeth, and no one may be interested in helping you. Sorry, but it would be like me, asking you to make me a shelf????????????
Do you have a link to what you're trying to make please??? Just to give us some idea, as there may be a better way etc.
12th Feb 2023, 05:17 PM #9Philomath in training
One thing Kryn has not asked - how many of each type are you looking for?
12th Feb 2023, 05:23 PM #10Most Valued Member
12th Feb 2023, 08:15 PM #11Member
- Dec 2015
- south coast, nsw
- 52
There are still a lot of questions remaining. I'll do the best I can to answer them.
Thanks for the pic, so basically the pieces will be 100mm X 100mm over all size? Yes
Will the metal need to be square on the edge, or can it be radiused? Square is best, can also handle radiused.
Will something be slid inside it, if anything, asking as the ends are left open? Yes, the timber components will slide into the open ends.
What happens to them once you get them, will they be screwed/bolted through the wood into the tube, or from the tube into the wood. Probably a screw or pin through the sides into the wood inside.
What is the thickness of the material, 1mm 1.6mm 5mm? 1.6mm should be fine.
What is the intended use of these pieces, to act as a spacer, or support a shelf? They are substitutes for timber joints. See later picture.
Do the welds need to be ground back or can they be left as is? Probably ground back is best, I can do that, but I'm not a welder.
How many of each piece is required? 4, see picture.
What weight is anticipated to be supported? Will support small coffee table.
Do you have a link to what you're trying to make please? No links, just my own ideas and design, as far as I know.
Sorry, can't sort these sideways pics.
12th Feb 2023, 08:54 PM #12Most Valued Member
Thanks for the pic of what you're trying to achieve, it now gives a better idea as to what is required.
Making it shouldn't be a problem at all, will see what I can find in the way of materials.
Will contact you with a price for it all, sometime during the week.
Regards,
13th Feb 2023, 05:41 AM #13
Hi Tiprat, Have a look at this link:
https://metalworkforums.com/f316/t20...sting-picturesBest Regards:
24th Feb 2023, 01:29 AM #14Member
- Dec 2015
- south coast, nsw
- 52
24th Feb 2023, 01:43 AM #15Most Valued Member
Sorry Tip Rat, I'd forgotten all about it, as I had to have some knee surgery done and still away from work, till next Thursday, will get into it then for you.
Thanks for the reminder, dam CRAFT disease!!!
Adelaide - Looking for a welder who can fix a small crack in 0.50mm sheet
By GWH74 in forum WELDINGReplies: 4Last Post: 24th Mar 2015, 08:01 AM -
Chatter when using 50mm face cutter
By 19brendan81 in forum METALWORK GENERALReplies: 29Last Post: 4th Sep 2012, 10:15 PM -
cutting thick plate (50mm) with oxy
By .RC. in forum WELDINGReplies: 5Last Post: 23rd Dec 2011, 07:48 PM -
50mm boring head set
By neksmerj in forum METALWORK GENERALReplies: 14Last Post: 23rd Mar 2011, 12:58 PM -
50mm Face Mill and 10 Mitsubishi Inserts for $CHEAP
By markjaffa in forum METALWORK GENERALReplies: 18Last Post: 11th Sep 2010, 02:23 PM
