Results 1 to 8 of 8
    Sep 2008
    Riddells Creek, Vic.
    838
    Default Waldown Toolpost Grinder - Collet type Internal spindle.
    I am after a Collet type spindle to suit a C1 grinder, the spindle model number is C1-C. It takes 1/8 and 1/4" collets.
    Also an Internal Long Reach spindle, model number C1-E
    Nov 2008
    Perth WA
    6,459
    Quote Originally Posted by Techo1 View Post
    Lex, I don't know if this will help because I don't know what the spindle thread is on a C-1 but the C-O with its 3/8"UNF thread enables the fitting of Dumore collet chucks. I bought the chucks new from the States to fit the Dumore 44 TPG I have.
    https://www.dumoretools.com/chuck-as...18-p-6024.html
    Bob.
    Sep 2008
    838
    Thanks for the information Bob, the C1 has a 1/2" Unf thread on the external spindle, do Dunmore make a collet chuck in that size? How do you lock the chuck onto the threaded spindle and does it run nice and true?
    Nov 2008
    Perth WA
    6,459
    Lex,
    I'm not sure about Dumore's larger grinders. They have interchangeable spindles whereas the 44 doesn't hence the accessory collet chucks. The chucks tighten against a spacer and the 1/4" chuck runs truer than the 1/8. Neither are perfect. Comes down to dressing the stone.
    This might be too large to be a consideration but.... https://www.aliexpress.com/item/4000...698d18026PGfCW
    Bob.
    Sep 2008
    838
    Yes, one of those would probably do the job although I am worried about how much runout they have especially considering the high speed required for a small mounted point. Some of the reviews do mention excessive runout.
    Nov 2008
    Perth WA
    6,459
    I have ordered a ER25 1/2 UNF version and it is on its way to Perth. My application is for a proposed milling spindle for use on my Hercus lathe's vertical milling slide and runout would be less of an issue than if it was mounted on a grinder spindle.
    I will let you know how good or bad it is when it rolls up.
    BT
    Nov 2008
    Perth WA
    6,459
    Just thinking Lex... how about a Dremel chuck mounted on a 1/2-20 adapter in a similar fashion to the Dumore ? You could cut the chuck's thread with the adapter mounted on the C-1 spindle to ensure concentricity.
    Sep 2008
    838
    That's another option Bob, although I would like to use 1/4" shanks mounted points as well.
  1. Waldown toolpost grinder spindle and castings
    By lamestllama in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 16th Sep 2021, 03:29 PM
  2. Waldown Toolpost Grinder - Alternate uses
    By LexD in forum METALWORK GENERAL
    Last Post: 24th Oct 2020, 10:01 AM
  3. Waldown Toolpost Grinder wanted.
    By LexD in forum WANTED TO BUY
    Last Post: 1st May 2020, 08:03 PM
  4. Waldown Toolpost Grinder
    By A J in WA in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 19th Jan 2019, 02:41 PM
  5. SOLD: Waldown toolpost grinder
    By Greg Q in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 28th Aug 2013, 02:17 PM
