Results 1 to 15 of 15
Thread: Richardson Drill Press
27th Oct 2022, 07:56 AM #1New Member
- Jan 2022
- Brisbane
- 1
Hello All
I am looking for a 6 step pulley for a Richardson drill press. Mine is cracked. Any leads would be appreciated.
LanceIMG_4035.jpgIMG_4034.jpgLast edited by zolanc; 27th Oct 2022 at 07:59 AM. Reason: add photo
27th Oct 2022, 10:04 AM #2Senior Member
- Oct 2010
- NSW
- 177
They're pretty hard to come by. I've been looking for a drive pulley for mine which seem to be the first to go.
27th Oct 2022, 07:06 PM #3Philomath in training
- 6,540
I doubt that you will find one out in the wild, particularly if they are prone to cracking like that. A remake may have to be the way to go. That triangular shape could be interesting to produce. Is it straight sided or curved? Go all the way thorugh or just for a small length? What are the overall dimensions? A chunk of Al that size would not be cheap though (just saying).
Picko, is yours the same or a different shape/ size?
27th Oct 2022, 07:29 PM #4
That pulley looks to have been cast ! I agree with Michael that the bore would be quite interesting to produce. How deep is it ?Best Regards:
28th Oct 2022, 08:53 AM #5Senior Member
- Oct 2010
- NSW
- 177
The drive pully just has a 5/8" hole for the motor shaft Michael, and is the same'ish' shape / size.
Here's a shot of one.
I can't tell you anything about the driven one because the closest I've ever needed to get to it is to replace the belt. I have a four step on it and for what I do it's OK but I would like to make it original one day if I can.
My mate has just bought a three head one like this but hasn't picked it up yet. Actually I should say he stole it - $102.50.
When he gets it home he'll need to keep an eye on it or a pulley might go walkabout.
28th Oct 2022, 09:39 AM #6Member: Blue and white apron brigade
- 7,182
I turned up a multistep pulley (LHS pulley in image below) for my small (0.5HP) wood working lathe using a piece of 75mm Al round bar.
I had to do this when I upgraded to a 1HP motor which had a 19mm bore V's the 5/8" bore of the original (RHS in image below)
The original pulley was hollow and did not have enough metal in the region of the bore to drill it out to 19mm.
From memory I bought enough Al to make two pulleys (in case I stuffed up) and it cost me about $75!
Hate to think what a piece for the OPs pulley would cost.
In the end I put a VFD on the lathe and now the belt sits more or less permanently in position #4 from the big end.
If I do move the belt its only +/- one step.
28th Oct 2022, 11:06 AM #7
I have seen people online repairing broken cast iron pulleys by clamping in a vice, grinding the cracks, brazing or welding the cracks and finally cleaning the welds by turning the pulley on a lathe.
As it stands you are unable to use the cracked pulley and might as well make it a weekend / backyard repair project. You can find a few videos on youtube that will help build some excitement into doing this.
It might be the best alternative while you continue looking for a replacement.
28th Oct 2022, 11:36 AM #8Senior Member
- Apr 2018
- 168
There used to be a company in O'conner WA that mainly sold blank drive pulleys. I bought a new blank drive pulley for my old japanese drill press from them about 5 years back and just bored it to suit.
Guys from Perth may know if its still around.
Another option is try and get the required steps in 2 pulleys and match them up to make the 6 steps. the 3 centre keyways would be easy to make with a broacher.
28th Oct 2022, 11:40 AM #9Senior Member
- Oct 2010
- NSW
- 177
I reacon Lance (OP) and I should go halves in a complete Richie and part it out. He takes the driven pulley and I take the drive pulley for starters. In the same auction in which my mate bought the three head unit, there were two other Richardsons, a floor unit and a bench drill. They went for $61 and $51. Had I known he was going to bid on the one he got I would have bid on the others and we could have shared the freight cost.
28th Oct 2022, 06:56 PM #10Philomath in training
- 6,540
28th Oct 2022, 10:15 PM #11Diamond Member
- N.W.Tasmania
- 1,407
Certainly buying a suitably sized lump of aluminium is likely to be expensive, but a couple of alternative options come to mind.
Option 1 would be to cast a suitable lump and then machine it to specification. I understand that alloy wheels are considered the gold standard for casting, so a trip to the wreckers might be in order to find some cheap accident damaged wheels. Others with considerable casting experience might care to comment on the suitability or otherwise of this idea, and any tricks or pitfalls to watch out for.
My other idea would be to make a wooden pulley. Some old well seasoned hardwood, perhaps an old Red Gum fence post or similar might work or alternatively something built up with suitable plywood. A metal core to carry any required keyway and with a flange on one end to enable the drive forces to transfer to the pulley could be incorporated if that was considered desirable.
Good luck with your project.
29th Oct 2022, 01:08 PM #12Member: Blue and white apron brigade
- 7,182
The OP also posted in the woodies forum and a member (Treecycle) iresponded with this interesting link
http://www.bearing.net.au/wp-content...um-Pulleys.pdf
The OP will still have to do something about the triangular bore but at least its worth know that the pulleys are supposedly still out there.
29th Oct 2022, 02:17 PM #13Philomath in training
- 6,540
My recent experiences with casting suggest that the cost difference in buying a cast lump and machining from billet are not that different - not sure whether that shows how the extra labour for a casting is balanced by the cost of the material that is not there or not...
I would guess it is about the amount of material that has to be removed from a theoretical billet to get to a casting, but a pulley is pretty compact, so the proportion removed would be less than say recreating the body of a drill press.
Once the overall dimensions of the pulley is known, the price of material is easy enough to determine. Until then
29th Oct 2022, 05:06 PM #14Most Valued Member
- 5,942
Hi Lance, what are the measurements of the pulley, OD and height, PLEASE?
Asking as I may be able to get a billet offcut from a contact here. Secondly, would you be able to machine it to size yourself, or have a contact there that could do it?
30th Oct 2022, 08:46 PM #15Most Valued Member
- Healesville
- 2,129
It might be possible to turn the top section of that broken pulley down and fit it into a 6 step pulley, maybe fit that below the smallest pulley groove where there is more meat....
If I was repairing this drill for myself. I am more into function than form so i would fit a 2 step pulley at each end and a 1 hp 4 pole 3 ph motor with a vfd....so much nicer to use.
By Reidy41 in forum METALWORK GENERALReplies: 11Last Post: 28th Oct 2022, 09:59 PM -
richardson drill press
By robyn2839 in forum METALWORK GENERALReplies: 5Last Post: 30th Jan 2022, 05:26 PM -
J S richardson drill press
By Glenn69 in forum METALWORK GENERALReplies: 3Last Post: 27th Jan 2022, 11:56 PM -
By robyn2839 in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 5th Jun 2019, 09:15 AM -
By stix012 in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 5th Feb 2018, 12:52 PM
