Results 1 to 4 of 4
27th Sep 2022, 07:28 PM #1Member
- Jul 2009
- perth
- 67
Set of outside jaws for 200mm 3 jaw chuck
8mm pitch otherwise dimensions as in sketch
The jaws do not have to be in excellent condition.
Thanks Tom
Sent from my SM-G965F using Tapatalk
28th Sep 2022, 12:11 AM #2
Hi Tom,
When I wanted a set of outside jaws for a 150 mm chuck I found it almost impossible to buy any at a reasonable price. I discovered that I could buy a set of new soft jaws for a fraction of the cost. I modified some 100 mm PB soft jaws so that I could screw replacement aluminium pieces on them. It might be the way to go.
28-07-2020-003.jpgBest Regards:
28th Sep 2022, 08:12 PM #3Senior Member
- Aug 2021
- 46
- 117
If you have a Chinese chuck there is a chance you’ll find a set on alibaba
29th Sep 2022, 01:20 PM #4Member
- Jul 2009
- perth
- 67
Thanks guys,
The soft jaws should suit my needs as the chuck will be used on a welding rotator as opposed to machining.
If I installed a good set they would most likely get wrecked quickly.
Thanks Tom.
Chuck jaws
By ptrott in forum METALWORK GENERALReplies: 21Last Post: 7th Feb 2020, 06:04 PM -
Are chuck jaws any good?
By DSEL74 in forum METALWORK GENERALReplies: 2Last Post: 15th Nov 2018, 08:58 PM -
unusual 3 jaws chuck . any one know ?
By thorens in forum METALWORK GENERALReplies: 4Last Post: 14th Sep 2015, 06:14 PM -
Spare 8" (200mm) 3-jaw chuck anyone?
By jhovel in forum METALWORK GENERALReplies: 17Last Post: 23rd Jun 2014, 09:38 AM -
Grinding chuck jaws
By jomac6 in forum THE HERCUS AREAReplies: 0Last Post: 15th Jun 2009, 11:56 PM
