Results 1 to 4 of 4
18th Aug 2022, 05:28 PM #1
WTB: Center/Intermediate pulley assembly and top belt cover for 12 speed drill press
I am trying to restore a Forbes Bench Drill Press FDB-16mm 12 speed (1976) that is missing the top belt cover.
A generic image of the drill press is below (copied from a members post on the woodwork forum) and the belt cover should be roughly in the dimensions of 563 x 190W x 75H:
I am also hoping to find the Center/Intermediate belt pulley assembly which looks similar to this:
These are fairly generic drill presses that were rebadged by various manufacturers and most parts should be interchangeable.
18th Aug 2022, 09:30 PM #2Most Valued Member
- 2,673
I’m away for the next couple of weeks so can’t check dimensions etc but I’ve got one pretty similar to that.
If you haven’t found anything closer by then please let me know and I’ll check it out.
18th Aug 2022, 11:33 PM #3
Thanks for the response. No dramas, I am in no rush so I can await your return.
All I know is that the shaft on the idler/center pulley assembly that mounts to the head of the drill press is roughly 13.5mm in diameter based on my caliper measurements of the mounting hole.
9th Sep 2022, 11:31 AM #4
I have found a center pulley and no longer looking for one.
I am still interested in finding a belt cover for the pulley assembly similar in dimensions and shape to what we can see below:
The cover can be described as below:
If you have one that's gathering dust and you want to give it a new home, lets get in touch and we can work something out.
Tough Drill Intermediate Pulley Question.
By Anorak Bob in forum METALWORK GENERALReplies: 14Last Post: 25th Nov 2018, 12:05 AM -
Pulley and Belt size speed ratio Calculator
By KBs PensNmore in forum CONVERSIONS & CALCULATIONSReplies: 0Last Post: 4th Dec 2017, 08:50 PM -
Pulley cover for Fidax drill
By kenny_10 in forum WANTED TO BUYReplies: 0Last Post: 28th Apr 2017, 01:09 PM -
Variable speed v-belt pulley assembly
By Petip in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 22nd Apr 2017, 08:37 AM -
Waldown 8SN drill press change belt/ speed questions
By thorens in forum METALWORK GENERALReplies: 8Last Post: 15th Sep 2013, 11:53 PM
