Results 1 to 11 of 11
    Oct 2012
    Mullaloo WA
    80
    Default 4 Jaw Chuck Wanted
    Smallish 4 jaw chuck wanted, my current lathe has a large 4 jaw chuck which I am increasing finding hard to move. It is 12 inches and heavy construction a lovely chuck but a bear to move around. I am now 73 years of age and no longer as strong as I used to be. What I want is a smaller. lighter chuck independent 4 jaw. My lathe has a D1-6 cam lock headstock which will limit my choices somewhat. A couple of fixes are fit a suitable backing plate to a chuck designed for a smaller one or rig up some sort of crane arrangement. Floating this to see if anyone has a redundant chuck sitting around. I am in Perth but would be willing to arrange a courier if needed. Heres hoping.
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    How small can you go and still fit the D1-6 camlock? Lathes.co.uk lists the OD at around 165mm (not sure exactly which one it it is), which means at least a 6 1/2" diameter. I think the next size up is probably 8"
    Nov 2017
    Geelong, Australia
    57
    2,665
    Assuming you’ve got a decent 3 jaw, another option is to just grip a smaller 4 jaw in that.
    Oct 2011
    59
    6,559
    It would probably work better the other way around - if the 3 jaw was in a large 4 jaw, you could centre stock in the 3 jaw without (hopefully) having too much of an off-centre load.
    Aug 2019
    Revesby - Sydney Australia
    57
    1,195
    That assumes the material is round or hex.
    Won't work for square or irregular
    Oct 2011
    59
    6,559
    Quote Originally Posted by nigelpearson View Post
    So you take the 3 jaw out and use the 4 jaw that is still attached to the lathe...
    Nov 2017
    Geelong, Australia
    57
    2,665
    I disagree Michael.
    With the caveat that the OP has a decent 3-jaw (ie suitable size and runs pretty true), putting a smaller 4-jaw in that won't introduce any off center load. The 4-jaw would be centered naturally.
    Obviously then chucking something off-center in the 4-jaw will, but no more than it will if that 4-jaw was mounted directly to the spindle.
    Unless you are referring to the off-center load in combination with the distance from the spindle. Yes - potentially slightly more "leverage" on the spindle due to the stick-out, but since we're talking small 4 jaw on a machine that can handle a large chuck anyway I don't think that would be an issue.
    Also - somewhat making the assumption that OP doesn't need the capacity of his large 4-jaw, is happy with whatever 3-jaw he has, and likely mostly uses that anyway. So keep the 3-jaw on, and throw in the small 4-jaw when required.
    Oct 2011
    59
    6,559
    If I have to do repetitive parts, I'd much prefer a 3 jaw to hold them and centre (or off centre) that chuck once in a 4 jaw than having to re-centre every time, which you would have to do if you had a small 4 jaw in a larger 3 jaw. The OP has a 12" 4 jaw, so that could hold a decent sized 3 jaw. I would imagine that his 3 jaw is 6 to 8", so the size of 4 jaw he could put in that would be far smaller.
    I'll have to disagree with your disagreement.
    Jun 2011
    Australia east coast
    2,713
    Yeah 8" is the go - I have an 8" 3 jaw on a D1-6 mount.
    I also have a 12" Bison 4 jaw and it's a LOT heavier than even the 10" 4 jaw chuck let alone the 3 jaw.
    So depending on the size of stuff needing to be gripped, I'd go for an 8" chuck. Lots on fleabay, probably as good a source as anywhere.
    I'm facing the same issues myself - getting older and not wanting to handle big/heavy chucks. I just fitted a 12" 4 jaw to my DS&G lathe because I had it there but I'm looking for smaller & lighter ones right now.
    As for gripping a smaller chuck in a larger one, I don't do that. Just don't like the idea.
    PDW
    Jun 2005
    Townsville, Tropical Nth Qld.
    226
    Well I am in the same boat age wise, so I built a swingarm above the lathe and use a $20 block and tackle to change my chucks. It's manual, but if I had the room, I would have an electric winch, cheap as at the big green shed.
    Rgds,
    Crocy.
    Oct 2012
    Mullaloo WA
    80
    Default 4 Jaw no longer needed.
    Thanks to all that replied, I no longer need this chuck, the lathe and existing chuck has been sold.
  1. Chuck Keys wanted.
    By colnjulia in forum WANTED TO BUY
    Last Post: 7th Oct 2020, 06:36 PM
  2. Wanted: outside Jaws, Vanco 6" 3 jaw chuck.
    By Gammaboy in forum WANTED TO BUY
    Last Post: 12th May 2016, 10:37 AM
  3. Wanted 3 Jaw Chuck for Hercus 9"
    By oggy in forum THE HERCUS AREA
    Last Post: 30th Mar 2016, 12:34 PM
  4. Wanted jaws for Burnerd 4" 3 jaw chuck.
    By Com_VC in forum THE HERCUS AREA
    Last Post: 31st Mar 2011, 11:51 AM
  5. Wanted four jaw chuck?
    By wildwesty in forum THE HERCUS AREA
    Last Post: 28th May 2009, 10:50 PM
