Results 1 to 6 of 6
Thread: WTB Hercus 260 ER32 collet chuck
22nd May 2022, 05:21 PM #1New Member
- Mar 2022
- 2
Does anyone have a Hercus 260 ER32 collet chuck they wish to sell? Prefer Adelaide area, but will consider interstate.
Thanks,
Wally
23rd May 2022, 08:53 AM #2Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
If you get one of these: https://tinyurl.com/2p8eye8u
and one of these: https://australianmetalworkinghobbyi...product_id=285
you can combine them with some careful fitting to your own particular lathe.
It's said to be a more accurate thing than a pre-made one piece chuck, or a two piece made for another lathe.
There may be size options that you can research.
24th May 2022, 09:12 PM #3Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,554
Or you can put an ER collet holder on a Morse taper shank into the spindle. Doesn’t allow your stock to go through the collet holder though, works well for small parts.
25th May 2022, 07:58 PM #4Mechanical Butcher
- Oct 2004
- 1,898
A Morse taper chuck would be alright, as long as it has a threaded end for a long bolt through the spindle.
It's a bit more fiddly to use compared to one that screws directly to the chuck mount thread.
But accuracy should be good "off the shelf", as long as it's made properly, and it would be interchangeable between lathes with the same spindle taper - assuming they are also made properly.
25th May 2022, 08:02 PM #5New Member
- Mar 2022
- 2
Thanks for all the ideas guys,
Wally
29th May 2022, 10:40 PM #6
Straight shank collet chuck
I use a straight shank ER33 collet chuck in my 4 jaw chuck.
It may be impractical in a chuck smaller than 150mm because of stick out.
But it works for me.
MarkI've become a tool of my tools.
SOLD: Vertex ER32 Collet and Chuck Set
By SurfinNev in forum METALWORK - Machinery, Equipment, MARKETReplies: 11Last Post: 6th Sep 2013, 09:06 PM -
Spindle Collet Chuck (ER32)
By DarBee in forum METALWORK GENERALReplies: 9Last Post: 25th Jun 2013, 10:19 PM -
ER32 Collet chuck - where to buy
By morrisman in forum METALWORK GENERALReplies: 24Last Post: 7th Jun 2011, 09:05 PM -
ER32 Collet Chuck to Suit Hercus 9 Lathes
By Col2310 in forum METALWORK GENERALReplies: 6Last Post: 10th Sep 2010, 09:26 AM -
By Col2310 in forum METALWORK GENERALReplies: 4Last Post: 3rd Jun 2010, 06:22 PM
