Results 1 to 6 of 6
Thread: Brass and copper swarf
17th Apr 2022, 10:15 PM #1Intermediate Member
- Apr 2019
- Salisbury, South Australia
- 37
- 29
Hey guys.
If anyone has brass or copper chips from machining that are clean I would love to buy them from you.
Even titanium and alloy or bronze
I have been casting the limited amount I have into resin for my knifemaking endeavours.
Sent from my SM-G998B using Tapatalk
17th Apr 2022, 10:52 PM #2Most Valued Member
- 5,942
I got a heap from my local M10 from their key cutting machine, it is mixed with aluminium, but should still make a nice effective handle.
If you're prepared to do some filing find some old brass taps and using a course file and some newspaper under the vise, file away to your hearts content.
HTH
17th Apr 2022, 11:23 PM #3Intermediate Member
- Apr 2019
- 37
- 29
That's not a bad idea check some locksmiths. They don't run coolant to cut keys.
I'm more looking for chips than filings. I have also cast filings in resin. Just not the same effect. And it tends to get dry spots no matter how much you stir it up. I wonder if a power rasp would make a larger filing that would work.
18th Apr 2022, 01:26 AM #4Most Valued Member
- 5,942
Instead of a course file you could try a rasp or a Farriers file, they are VERY course for trimming horses hooves.
I don't think a power file will do the trick as they are more of a sander and give fine pieces.
18th Apr 2022, 10:14 AM #5
Where are you located? Postage could be costly.
Sent from my SM-T580 using Tapatalk
18th Apr 2022, 11:20 AM #6Senior Member
- Apr 2018
- 168
have you tried a local scrap metal dealer.
I often see 44 gal drums of brass / bronze swarf in their yard.
Heavy wall brass or copper pipe
By China in forum WANTED TO BUYReplies: 5Last Post: 29th Jan 2020, 03:13 PM -
Small square of brass or copper
By racingtadpole in forum WANTED TO BUYReplies: 4Last Post: 28th Jan 2020, 08:31 PM -
Need help !! about polishing soldered brass/copper jewelry.
By jmorbid in forum JEWELLERYReplies: 28Last Post: 4th Dec 2016, 02:33 PM -
Supplier for thin (4-6mm OD) copper or brass tubing
By StevenManos in forum METALWORK GENERALReplies: 6Last Post: 7th Jun 2016, 09:02 AM -
Brass/Copper finish
By cookie48 in forum METALWORK GENERALReplies: 2Last Post: 7th Jul 2011, 09:14 PM
