Results 1 to 5 of 5
Thread: Coolant Buk Buy
8th Mar 2022, 05:33 PM #1Member
- Oct 2012
- Mullaloo WA
- 80
Coolant Buk Buy
Is there anyone in the Perth Metro that would be interested in going shares in a 20 litre drum of top shelf Full synthetic coolant.
They are available for about $500 for 20 litres, dilute it at 70:1 and it would well outlast me, anyone want a half or quarter share
haven't decided on a brand and open to suggestions.
8th Mar 2022, 06:20 PM #2Member: Blue and white apron brigade
That looks like Rocol RY561411 ($503 for 20L from Blackwood's) to me but the 70:1 is for Grinding and it uses 60:1 for cutting.
If so, I would consider purchasing 5L.
I still have about 2 of ~5L of some 40:1 Rocol I got about 6 years ago but I wouldn't mind having some back up.
We used Rocol at work and I found it to be really good.
If you wanted to save $75 you could always get the RY563011 ($428 for 20L) but it's only 35:1 dilution.
8th Mar 2022, 08:15 PM #3Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
I would not recommend a full synthetic coolant, we used some at work for a while and it stripped all the paint off the inside of the mills, caused really bad corrosion issues, and a few $K in repairs.
8th Mar 2022, 10:29 PM #4Member
- Oct 2012
- Mullaloo WA
- 80
Coolant Bulk Buy
Thanks Bob if I get one two more starters it could happen, will keep in touch.
Cheers Col
8th Mar 2022, 10:51 PM #5Member: Blue and white apron brigade
The $428 ROCOL is semi synthetic - or at least it says that on its MSDS,
The $503 doesn't say whether it is or not.
All of the ferrous cutting lubes on the ROCOL site are semi synthetic but they use a different product numbering system is I cant tell what the Backwoods ones are.
The ROCOL one I have (cant remember teh number) does not remove paint so I assume its not synthetic.
Coolant - yet again
By bollie7 in forum METALWORK GENERALReplies: 19Last Post: 8th Jan 2020, 10:33 AM -
What Coolant
By Auskart in forum METALWORK GENERALReplies: 6Last Post: 29th Mar 2019, 09:01 PM -
Do I need to run coolant?
By RustyArc in forum METALWORK GENERALReplies: 5Last Post: 10th Feb 2019, 10:16 PM -
Coolant
By CGroves in forum METALWORK GENERALReplies: 3Last Post: 23rd May 2012, 08:35 PM
