Results 1 to 9 of 9
15th Feb 2022, 12:14 AM #1Most Valued Member
Press V block and knife blade to purchase
HI all, looking for a piece of brake press V block and knife blade or a V bottom edge, to buy, about 100mm long or thereabouts. If anyone has some that is/are no longer required or know of some for sale please PM me. Wanting it to press 1.2mm sheet metal, so it doesn't need to be a very wide V, probably about 20mm should be fine.
I keep looking on Gumtree etc, to no avail.
Thanks in advance,
15th Feb 2022, 06:42 AM #2Philomath in training
Kryn, have you seen these?
https://www.supercheapauto.com.au/p/...ke/593989.html
Had one (not kincrome brand) for some time and it comes in handy.
15th Feb 2022, 02:37 PM #3
Hi Kyrn,
How about a piece of earth moving bucket cutting edge. They are often a bolt -on replaceable and often the whole set is replaced.
Sometimes the vertical strips-the ones on the side are in pretty good nick.
If some one has a piece of laying about. I thought I had a good piece but Mrs Clean up fairy has been operating out of bounds and I suspect it went to the tip.
15th Feb 2022, 06:03 PM #4Most Valued Member
Thanks Michael, I have seen them, unfortunately there's not enough room in my vise to operate that set up, planning on mounting it under an arbour press.
Thanks Grahame, I hadn't thought about using an earth moving blade.
Next door has a few graders and dozers parked there, I wonder if they'd miss a piece???
Thanks again,
15th Feb 2022, 10:20 PM #5Most Valued Member
- 2,671
For my little 6T Supercrap press I made up a quick and dirty set about the length you are after.
3 pieces of angle iron (Probably 30x30x5 from memory) laid out in an upside down W shape and welded together as the bottom die, and a piece of flat bar ground to the knife shape.
Worked well.
15th Feb 2022, 10:54 PM #6Most Valued Member
Hi Steve, done that one, I use it for thicker flat bar, 4mm+. Sheet metal doesn't come out as nice in it. Did the last batch of 30 in the hydraulic folder, but it took ages, 2hrs, and still weren't great.
What I'm trying to achieve, is like a brake press, with an edge that will keep it square and with an adjustable stop, as what I'm making has 2 bends in each piece. The first bend is 15mm in from the edge and bent right over and flattened, (a safety edge) then 120mm from that bend a 90 degree bend.
It drops in beside the battery and winch cover, on our sheep ramps to hold the hand control for the winch.
17th Feb 2022, 12:00 PM #7
Hi Kyrn,
I don't know if you have done this before but its worthy of a mention.
The inside of the bend line can be scored light with a angle grinder cutter blade. One of the 1mm th. cutter discs ones works well.
The trick is to make a single, smooth, even travel speed pass of even depth.
Under a folder it bends nice and even, IF, the scoring pass is uniform across its length. If the scoring pass is irregular so is the external appearance of the bend.
I clamped a bit of flat to the bend line and ran the wheel against it.
17th Feb 2022, 02:22 PM #8Senior Member
- May 2010
- 135
19th Feb 2022, 12:56 AM #9Most Valued Member
Thanks Des, that's thinking OUTSIDE of the box, hadn't thought of that idea!!!!!
Might give it a try.
Fly cutter for pocket knife blade slot
By Grahame Collins in forum METALWORK GENERALReplies: 4Last Post: 4th Mar 2020, 04:43 PM -
Help & Advice with a newDrill press purchase choice
By jedimindtime in forum METALWORK GENERALReplies: 19Last Post: 30th Oct 2018, 08:20 PM -
Universal Bender, hand pipe bender, knurling tool, arbor press, chain block
By John T K in forum METALWORK - Machinery, Equipment, MARKETReplies: 12Last Post: 17th Jul 2018, 12:02 AM -
Stanley Knife Blade as Finishing Tool ?
By steamingbill in forum METALWORK GENERALReplies: 4Last Post: 13th Aug 2016, 12:10 AM -
Waldown knife / blade grinder, Info Wanted
By lightwood in forum METALWORK GENERALReplies: 9Last Post: 27th Apr 2012, 12:50 AM
