Results 1 to 13 of 13
25th Aug 2021, 02:25 PM #1New Member
- Aug 2021
- Nsw
- 9
32 & 40 tooth gears for al960b lathe
Hi, new to this, I was after 32 & 40 tooth gears for al960b lathe wondering if you could help me.
26th Aug 2021, 07:45 PM #2Senior Member
- Aug 2012
- Greenmount, W.A.
- 70
- 275
Helo Ross - welcome to the Forum.
I can't help with the gears. I am surprised they did not come with the lathe.
I helped a friend a few years ago with repairing a Chinese made lathe that came to him in a number of boxes! The previous owner had pulled the geared head apart, and stated changing the wiring! He got the lot for $150.00! Only took three months full-time to fix it. Being retired it did not bother him, and he had a Hercus to make any bits he needed.
It was a Hare and Forbes badged lathe, but their support documentation was not of much help, and I found the same lathe advertised by Grizzly in the US. Their documentation was superb!
Therefore look at Grizzly, and anywhere else in the USA and you may find the same lathe, and perhaps the gears you want. I would be surprised if you didn't.
See this thread on the Forum for information about the gears your lathe:
https://metalworkforums.com/f65/t186...-tooth-profile
Regards,
Alan.
26th Aug 2021, 10:55 PM #3Philomath in training
- 6,562
I have the necessary M1.25 cutters. I could cut some if I knew the bore etc.
27th Aug 2021, 09:17 AM #4
Michael, I have an AL960B, I'll measure the bore and width later today and post the details.
If you end up making the 32 & 40 tooth gears (which are the standard kit supplied with the lathe) it might be worth making a 28T gear as well. That way he'll be able to cut a 1.75mm pitch thread which the standard gears will not cater for. A group of us had some of those made back in 2011.
If you need to borrow the gears to assist in the making, let me know.
27th Aug 2021, 10:32 AM #5
As standard, the AL960B should have 2 x 40T, 1 x 30T, 1 x 32T and the 120/127T gears. We added the 28T to enable 1.75 and 3.5 pitch threading (28-127/120-32 A6=3.5, B6=1.75).
If you are making gears Michael, the bore is 18 mm, the width is 10 mm. The keyway is 5 mm wide x 2.5 mm deep.
27th Aug 2021, 02:53 PM #6New Member
- Aug 2021
- Nsw
- 9
Hi Michael G , yes am interested in your making the gears for me, the bore is 18mm as previously stated. I not sure how to navigate this site so bare with me.
27th Aug 2021, 03:14 PM #7New Member
- Aug 2021
- Nsw
- 9
27th Aug 2021, 05:18 PM #8Senior Member
- May 2013
- Rockhampton, QLD
- 68
- 455
Welcome to the forum Ross.
Ross
28th Aug 2021, 11:22 AM #9
Hi Ross
Welcome to the MetalWorkforums.
There are lots of good people here who are supportive friendly and helpful.
Please take the time to navigate around the forums to view the varied and interesting subjects.
To do this, goto the the FORUM box in the top left hand corner of the screen. Click Forum Home and a scroll down page will come up.
Scroll down the page and the various help pages and sub forums shall be shown.
Please read the Terms of Use on the very top of the scroll down page - they are our rules.
To save time here's the link:
https://metalworkforums.com/f90/t197...terms-tou-read. Every member should read this document as a guide to what is acceptable here in the Forums and what is not.
Many pages also have a sticky at the top. If you post,in a particular page or forum its always a good idea to check the sticky ,if there is one there.
Please post your questions in the appropriate MetalWork forum.If not sure I am only an email way.
Again, welcome to our forums.
8th Sep 2021, 03:09 PM #10New Member
- Aug 2021
- Nsw
- 9
8th Sep 2021, 09:43 PM #11
Ross 971,
Its up to you to contact Michael.
If you are not sure how to make private contact with him, all that's required is to PM him is to left click on his name in the left hand top cnr of the post.
In the box that will appear click on "Send PM".
Its a huge favor he is doing for you,or will do. Better to do as much as you can, to set him up so he does not have to chase you to do a favor for you.
Normally most people would have thanked him for just for making the offer.
A bit of gratitude and courtesy goes a long way.
9th Sep 2021, 09:44 AM #12New Member
- Aug 2021
- Nsw
- 9
Hi Grahame Collins, I am having some trouble navigating the forum, when I click on the person's name it takes me to there profile basic information not the PM message, I am using a iPhone any help would be appreciated. Cheers Ross
9th Sep 2021, 11:56 AM #13
Hi Ross,
I don't own an iPhone and have never used a mobile phone of any version to contact then MetalWork Forums.
Hopefully a member who has an iPhone may be able to help you with advice.
Sorry that's all I can do to help. As I understand the original Forum template was set up for computer not for mobile phones.That said the system has been cobbled to adapt so its not perfect.
Perth - Lathe AL960B
By bigeye in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 22nd Sep 2019, 12:13 AM -
AL960b change gear tooth profile?
By variant22 in forum METALWORK GENERALReplies: 16Last Post: 22nd Nov 2014, 07:21 PM -
30 tooth gear for Herless lathe needed
By Kentower in forum METALWORK GENERALReplies: 12Last Post: 23rd Jun 2011, 07:08 PM -
28 tooth gears finally arrived
By rfurzer in forum METALWORK GENERALReplies: 2Last Post: 23rd Mar 2011, 11:50 PM -
Hafco Model AL960B Lathe
By Child Of God in forum METALWORK GENERALReplies: 4Last Post: 22nd Nov 2009, 07:02 AM
