Results 1 to 6 of 6
    Jun 2005
    Helensburgh
    618
    Default Two Small 3 phase Motors - NSW
    I am after 2 x 3 phase motors about 1 - 2kw. I am thinking of building two linishers shown in the video if the budget is reasonable.
    CHRIS
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Hello Chris,
    I have a few but only have details of one at present, I won't have the others details until Sunday.
    3/4 HP, 1440, 4 pole, Star ,1.5amp, 50 cycles, continuous.
    Jun 2005
    Helensburgh
    618
    Hello Chris,
    Thanks for the reply, keep me posted, they sound exactly what I am looking for.
    CHRIS
    7,189
    Not sure what size belt you are intending to run but my experience is that 3/4Hp is going to be too light for a 50 mm wide belt.
    My small Linisher has a 50mm wide belt and a 1HP motor and it's still relatively easy to bog down.
    A well designed linishers like a Radius Master uses a 2HP 2880 rpm motor for a 50 mm belt.
    Its spec says 3000 fpm for belt speed which means it must be using about a 4" drum.
    If the linisher is to be used for heavy grinding even better would be ~4500 fpm
    This could be achieved with a 6" drum or a VFD.
    If a 1440 rpm motor is used, to reach 3000 fpm with a 4" drum and a VFD means operating at 100Hz, while 4500 fpm means 137Hz, in this zone standard 3P motor will loose considerable power
    A 2880 rpm motor will reach 4500 fpm at about 75Hz - well within the original motor spec HP.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Hello Chris,
    Chris the other 2 I have are 1/2HP, 1425rpm, B56 frame, Y connection, class E insulation, cont rating, 5/8" & 3/4" shafts.
    The large shaft one has a slightly different cast body , it has a half flange mounting.
    Jun 2005
    Helensburgh
    618
    Thanks for taking the time to look for me but I will pass on them.
    CHRIS
  1. three phase electric motors
    By dodge at4 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 9th Sep 2017, 08:56 PM
  2. Replies: 11
    Last Post: 18th Mar 2014, 09:23 AM
  3. 1HP 3 phase motors x 2
    By jhovel in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 7th Aug 2012, 12:15 AM
  4. free 3 phase motors
    Last Post: 26th Feb 2011, 08:13 AM
