Results 1 to 5 of 5
    Mar 2011
    5
    Default Wtb - 3hp (2.2kw) ~2800rpm 240v motor with 19mm shaft
    Got a 3hp dust collector but the motor is 3 phase and apparently busted. I dont have 3phase so looking to swap it out for a 240v which i thought would be easy to source... oops
    7,189
    How do you know its busted?
    It's pretty easy to check if teh wirings are intact.
    1) Check the resistances of each of the windings and make sure they are all the same - a few ohms
    2) Check the resistance of windings to earth should be more than 2MΩ
    Post a poor of the motor junction box - it may be possible to run it off a 240V SP to 24V 3P supply using a VFD, OR using a 240- 415V VFD.
    The added benefit of using a VFD is that the impeller can be spun at 60Hz providing about 20% more air flow.
    Mar 2011
    Southern Flinders Ranges
    1,555
    A VFD on a dust extraction unit... nothing like over complicating things.
    I have some motors floating around I知 prepared to part with, I値l have a look and see if I have anything close to your requirements and report back.
    7,189
    3P motors and VFDs are increasingly being used on dust extractors (DE). Most machinery out of China is designed for the north american market (60Hz) but DEs machines don't use pulleys so their pulleys cannot be changed to recover speeds @ 50Hz. As a result most DEs sold in Australian underperform their North American versions by 20% . In some cases it is possible to drive the DEs at 65 or 70 Hz garnering even greater performance. 20% doesn't sound like much but most DIYer DEs need every bit of suck they can get.
    With increased speed comes increased noise and although DEs can (and should) be located or vented outside a shed, if a DC is set up right the air ducting intake/inlets on machines should be making a loud (ie irritating) hissing sound. If it's not doing this there's probably not enough flow even at 50Hz. For me this means wearing ear muffs even for relatively quiet tasks like turning and sanding. However, for tasks small workpiece jobs, high flows may not be required which means the DE speed can be reduced to <50Hz My DC is set up with outboard speed control but to make things easier I have set up a switch which dials in 40 - 50 - 60Hz.
    Just a heads up with motors for DEs, they some are flange mounted (although making a foot-flange adapter is not out of out of the question) and more some need to have longer shafts than usual.
    Mar 2011
    5
    Hey [mention]racingtadpole [/mention] did you have any luck?
  1. 240V Motor for SG
    By KBs PensNmore in forum METALWORK GENERAL
    Last Post: 11th Mar 2020, 10:55 AM
  2. 2.2kw - 3hp 240 volt motor 2800rpm
    By dodge at4 in forum WANTED TO BUY
    Last Post: 28th Sep 2018, 08:37 PM
  3. 240v electric motor
    By Turbine Builder in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 4th Sep 2018, 10:01 AM
  4. Compact half hp 240V motor
    By GDD in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 26th Jul 2018, 04:29 PM
  5. VFD for 240V single phase motor
    Last Post: 25th Feb 2011, 07:13 PM
