Results 1 to 6 of 6
    Dec 2020
    35 partridge road monash 5342
    3
    Default S16 repco power precision surface grinder service/operating manual
    I wish to buy/borrow/hire a operating/service manual and hydraulic schematic drawings for this machine.
    I purchased this machine from Whyalla steel mills and have restored it but I cannot get the hydraulics to work properly. can any one please help.
    raym
    Dec 2005
    South Australia
    1,658
    Welcome to the forum can't help with you request although remove you full address for security
    Apr 2012
    Healesville
    2,129
    Quote Originally Posted by ray mitchell View Post
    raym
    The 1st thing i would do is check that the pump is running the correct direction.
    Dec 2020
    3
    Default S16 repco power surfase grinder
    Thank you for your reply but have already checked that ,the problem seems to be in the hydraulic control side,hence the reason I need a hydraulics drawing.
    Mar 2014
    South of Adelaide
    1,227
    can you describe the problems you are having? might be able to help.
    Dec 2020
    3
    Hi snap trap, I have replied but must have put it in the wrong place.
    When I started the machine the piston for the cross slide had sheared off the shaft,I made a new shaft and re pinned the piston, started the hydraulic motor - the cross slide would move L and R with a few seconds delay at the end of each stroke. the speed control and L and R controls appear to be functioning but slow.The grinder in\out slide does not work at all, there is oil flowing through the hydraulic motor and I can
    change the direction of flow with the change over control. I removed the hydraulic motor and connected it to a power pack and it works fine, I tried reducing the bypass at the main hydraulic pump, the cross slide increased speed dramatically - too fast and the hydraulics became noisy . this machine has a hand wheel that when it is pushed in the slide can be moved manually , when I pulled the hand wheel out the machine became noisy and the hydraulic pump motor cut out on overload.
    I am reluctant to start pulling the hydraulic controls apart without a diagram to show how it works.
    I hope I have described things adequately and you are able to help.
    I look forward to hearing from you.
    Regards.
    Ray Mitchell.
  1. Repco Surface Grinder $1200
    By KBs PensNmore in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 10th Sep 2022, 09:34 AM
  2. B&S No2 manual surface grinder for sale
    By jhovel in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 27th Jan 2020, 11:07 AM
  3. Brown and Sharpe No 2 surface grinder manual
    By StrayAlien in forum METALWORK GENERAL
    Last Post: 1st Oct 2016, 11:25 PM
  4. Repco Power type C10 cylindrical grinder
    By shedeng in forum METALWORK GENERAL
    Last Post: 20th Oct 2015, 03:49 AM
  5. How much does a Repco Power S1 Surface Grinder weigh?
    By Gestalt in forum METALWORK GENERAL
    Last Post: 1st Mar 2015, 07:22 PM
