Results 1 to 3 of 3
8th Dec 2020, 05:07 PM #1Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
AL-54B lathe (Hafco) - apron gear wanted
Someone I know is looking to buy one of these lathes, with a broken gear.
It's attached to the apron handwheel.
Any chance there's a wrecked lathe being parted out for spares?
8th Dec 2020, 05:45 PM #2
Hi nadroj,
A long shot here perhaps.
If the gear is broken, I take it that the apron gear box will be disassembled in due course.
If you were to measure and provide all the broken part dimensions,bore diameters ,shaft diameter (if any), number of teeth etcetera. Somebody with a pile of parts who did not recognise their gear parts as a potentially correct part ( for you ) as an Al 54B .
Possibly they may have something that might fit.
There's likely to be other clones around.
If its similar in build to one of the yank Grizzly line, there are parts for some of the latter ones. Check em out through Grizzliy's on line site, but these days the freight will cost more than the part.
Just a thought.
8th Dec 2020, 09:13 PM #3Philomath in training
As it is a lathe that H&F have stocked, you might get lucky and they will have parts.
I had something similar a lathe or so agoand got a local gear shop to make one. Effectively a gear on the end of a shaft, it was around $150 a few decades ago. These days I'd cut my own as it was not a complicated part. Worth keeping in mind.
Hafco AL50G 9 x 19 lathe carbide tool advice wanted
By Johnny Rocker in forum METALWORK GENERALReplies: 11Last Post: 7th Mar 2019, 05:05 PM -
Wanted: Small/medium Sized Geared head Lathe with quick change gear box
By ml018 in forum WANTED TO BUYReplies: 0Last Post: 13th Apr 2018, 07:45 PM -
Hafco AL960-B gear noise
By MOA in forum METALWORK GENERALReplies: 11Last Post: 27th May 2015, 06:33 PM -
Need a 38 tooth change gear for Hafco AL340 lathe
By bob ward in forum METALWORK GENERALReplies: 4Last Post: 15th Jan 2015, 03:30 PM -
Apron Gear Lubrication
By toolman49 in forum METALWORK GENERALReplies: 0Last Post: 13th Nov 2011, 04:27 PM
