Results 1 to 12 of 12
Thread: Cast iron hot plate
30th Nov 2020, 04:06 PM #1China
- Dec 2005
- South Australia
- 1,658
Cast iron hot plate
Ok something I thought would be easy to buy has proved just the opposite, any one have a old cast iron hot plate 200mm diam 3-4-5mm thick or piece of cast iron I could cut
30th Nov 2020, 06:08 PM #2Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
May have, I’ll check for you tomorrow, senility has set in and I can’t remember if we have ditched the rusted out barbecue already or whether it’s still round the back of the lawn mower shed.
30th Nov 2020, 08:33 PM #3China
- Dec 2005
- South Australia
- 1,658
No Probs, just so long as it was not it back of the ute.
30th Nov 2020, 08:50 PM #4Golden Member
- May 2020
- Willowbank QLD
- 535
I saw a piece like that this morning on my drive to work, it was in the middle of a busy intersection and had a nice raised check pattern on it which would help with grease runoff. The funning thing is it had the letters PMG on it as well.
30th Nov 2020, 10:15 PM #5China
- Dec 2005
- South Australia
- 1,658
You a should grabbed it have you seen what the ones with PMG on sell for at the auctions, just to be safe you could have left a orange witches hat in it's place.
30th Nov 2020, 10:20 PM #6China
- Dec 2005
- South Australia
- 1,658
I probably should have made it a bit clearer this is not for a BBQ, it is to go on top of a 200mm electric element, that used to have a glass top it will not be use for cooking, I could most likely just use steel but I though that cast iron would heat more evenly
1st Dec 2020, 06:35 AM #7Philomath in training
Might be worth crusing the local op shops, see if they have a beat up cast iron skillet.
1st Dec 2020, 05:30 PM #8Most Valued Member
- Mar 2011
- 1,555
Reporting back.. I don’t have one
Should I be concerned that I don’t remember taking a barbecue that would have filled most of the back of my Ute to the dump?
1st Dec 2020, 09:26 PM #9China
- Dec 2005
- South Australia
- 1,658
No Don't be concerned it happens to all of us eventually.
Good idea Michael Why did I not think of it
4th Dec 2020, 03:34 PM #10Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
I saw a demonstration comparing aluminium and cast iron frying pans.
Both were sprinkled with flour then placed on a gas stove.
Burn patterns showed that heat was not evenly distributed in either pan. So the CI was no better than Al in terms of evenly heating.
But iron does retain heat longer.
4th Dec 2020, 08:12 PM #11Senior Member
- Apr 2018
- 168
9th Dec 2020, 11:44 PM #12China
- Dec 2005
- South Australia
- 1,658
Should have updated earlier problem has been solved, obtained frying pan with a broken handle form the camping shop ($0)
they were just throwing it out.
Scraping a cast iron surface plate
By lamestllama in forum METALWORK GENERALReplies: 21Last Post: 27th Nov 2020, 11:37 PM -
WTB-Cast Small Cast Iron Lapping Plate
By Betnorm in forum WANTED TO BUYReplies: 4Last Post: 19th Nov 2019, 01:01 PM -
12 x 24 inch cast iron surface plate
By iron bark in forum METALWORK - Machinery, Equipment, MARKETReplies: 4Last Post: 3rd Mar 2018, 01:30 PM -
Large Cast Iron Plate - What for?
By DSEL74 in forum METALWORK GENERALReplies: 14Last Post: 28th Jul 2015, 12:21 PM -
BBQ cast iron plate for sharpening?
By Dengue in forum METALWORK GENERALReplies: 4Last Post: 24th Aug 2014, 08:33 PM
