Results 1 to 1 of 1
1st Oct 2020, 01:32 PM #1Member
- May 2012
- Dandenong
- 76
Chasing steel plate approx 900 x 600 x 10-15mm thick
Hi all, long shot but you never know, I'm after a steel plate roughly 900 x 600 x 10 to 15mm thick to support a flypress on a trolley I'm working on, and I'm having trouble getting one at a reasonable price, so if anyone near either Hawthorne or Dandenong/Mulgrave area has one about that size, especially more towards the thicker end I'd be interested.
10mm probably won't quite cut it, but I figure if it's cheap enough I can add bracing. Around 15mm would be ideal.
Or even if you know of a place in the locations above that will sell less than a 2400 x 1200, and at a price I don't need a second mortgage on?
cheers, Ian
Chasing metal plate approx 900 x 600 x 12-15mm thick
By aarggh in forum WANTED TO BUYReplies: 0Last Post: 30th Sep 2020, 08:19 PM -
Chasing ideas for a sort of Friction plate material
By BobL in forum METALWORK GENERALReplies: 13Last Post: 22nd Feb 2017, 12:04 AM -
welding thick steel sections
By markgray in forum WELDINGReplies: 14Last Post: 6th Jun 2016, 07:23 PM -
cutting thick plate (50mm) with oxy
By .RC. in forum WELDINGReplies: 5Last Post: 23rd Dec 2011, 07:48 PM -
Suppliers of small quantites of thick Aluminium plate
By chrisw in forum METALWORK GENERALReplies: 3Last Post: 15th Jan 2010, 10:14 PM
