Results 1 to 9 of 9
    May 2011
    Murray Bridge S Aust.
    5,942
    Default Hardened Drill Guides
    Wanting to buy 3 drill guides, size number 11 for the pop rivets, if anyone has a few laying around. Preferably with a collar to stop them falling through.
    Can't seem to find them on Fleabuy, either that or I'm looking for the wrong thing.
    Thanks in Advance,
    Sep 2008
    Riddells Creek, Vic.
    831
    I didn't think that anyone in Australia would still be making drill bushes, but apparently, at least one company does: https://www.fjbushings.com.au/
    Aug 2006
    1,105
    Would the inner section of a bearing be suitable as a drill guide?
    May 2011
    5,942
    I suppose it would do, just a matter of finding some that size. 4.85 mm or .191" could be a tricky thing to find. Will speak to the bearing blokes tomorrow.
    Thanks,
    Mar 2011
    Southern Flinders Ranges
    1,536
    I have some 7/8” 4140 I acquired recently, I could cut a few small pieces off and put a #11 hole through it for you if that would work?
    Aug 2006
    1,105
    Thanks,
    I was just curious if the bearing material would be suitable for the purpose, not sure they would have something suitable in the size you are after.
    I have some 16mm diameter holes to drill soon and finding a bearing with that ID wouldn't be too difficult.
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,540
    Quote Originally Posted by Com_VC View Post
    It really depends on how much use the jig will get as to whether bearing steel would work. Certainly better than MS though. The big problem with using a bearing inner is that they are quite squat, so hole alignment becomes harder. You also need to secure them. Most drill guides are either long enough (2 to 3x diameter) to push into a frame or have a flange for attachment.
    May 2011
    5,942
    Thanks Adam, I'm getting Michael to make up some for me.
    Thanks again.
    May 2011
    5,942
    The jig gets used quite often, 3 holes per plate. It's used for making the clearance light plates on trailers. Recently did 22 plates for the one trailer, some take only 6 but on average about 10 per trailer, times that by 6 trailers a month, = 180 holes per month.
    Trying to talk boss into getting a punch and shear machine is like pulling teeth!!!!!!
  1. Guides for installing and setting up a mill?
    By takai in forum METALWORK GENERAL
    Last Post: 25th Mar 2020, 08:21 PM
  2. valve guides
    Last Post: 13th May 2017, 06:13 PM
  3. turning hardened steel
    By tanii51 in forum THE HERCUS AREA
    Last Post: 24th Jul 2009, 12:04 AM
  4. Milling hardened steel
    By glock40sw in forum METALWORK GENERAL
    Last Post: 26th Jul 2007, 04:46 PM
  5. Hydraulics - learning guides
    By Clinton1 in forum METALWORK GENERAL
    Last Post: 22nd Oct 2005, 12:34 AM
