Results 1 to 6 of 6
Thread: 22 mm Slitting Saw Arbor
6th Aug 2020, 12:32 PM #1Golden Member
- Apr 2009
- Kingswood
- 930
Have watched Ausee and M & G for the last few months waiting for 22 mm slitting saw arbors to come into stock - still nothing.
They seem to be rare everywhere.
Next search will be on UK/European sites.
Prefer a NT30 fitting, but parallel shank (20 mm max) is fine.
Any reasonable price paid.
Keep well,
John.
6th Aug 2020, 01:11 PM #2
I looked everywhere for one of these. I was after a 16mm and a 22mm arbor with a NT30 taper, for use with gear cutters. In the end, I found a place in Qld, ETS Engineering supplies. STUB MILL ARBOR NT30 X 22MM, Stub Mill Arbor - Engineering Tooling Supplies They have shipped me the 16mm version, but the 22mm version is on back order. Things out of China are very slow at the moment, but they tell me I will get it in around 2 weeks. The 16mm one that has arrived looks ok. I was surprised at how long it is (a lot longer than the photo on their web site) - good, I suppose for versatility, but maybe a rigidity problem if you mount the cutter too far out from the taper end. Anyway, give them a call and see if they can help. The other mob I tried was Chevpac Machinery NZ Ltd. They had the goods, but postage and exchange rate were going to add a fair bit to the cost. Cheers, Tony
6th Aug 2020, 04:17 PM #3Golden Member
- Apr 2009
- Kingswood
- 930
Tony.
Thanks for the link.
Ordered one (they show as " in-stock"), but I am sure I will also get the delay.
Really pleased it is NT30, the 16 mm arbor I have is 12 mm shank, it works but not ideal.
I have a fairly complete set of arbors for my small mill, but all MT2 arbor.
Keep well,
John.
6th Aug 2020, 04:31 PM #4
John, pleased to be able to help. The 16mm one arrived quickly and with no fuss, but the 22mm one on back order has taken over a month - I've contacted them a couple of times and have no reason to believe they are not 'on the job'. They were as surprised as me that the shipping from China has taken so long. They reckon 2 more weeks. Fingers crossed.
Thanks too for the good wishes. Challenging times here in Melbourne....and Australia....the world. No covid in the workshop - isolation could be worse .
Cheers, Tony
6th Aug 2020, 09:48 PM #5Most Valued Member
- 2,651
If you happen to already have an ER40 collet arbor then R8 arbors mount nicely in them. Probably not the most rigid setup ever, but I cut about 300 M1.5 teeth full depth with this setup the other day with no issues.
10th Aug 2020, 09:32 PM #6Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,536
LPR Toolmakers are showing them in stock.
Wanted: R8 to B16 arbor or decent R8 drill chuck and arbor
By caskwarrior in forum WANTED TO BUYReplies: 0Last Post: 4th Aug 2016, 05:42 PM -
CTC arbor for slitting saw
By eskimo in forum METALWORK GENERALReplies: 1Last Post: 18th Feb 2013, 10:58 AM -
Slitting saw arbor
By morrisman in forum METALWORK GENERALReplies: 10Last Post: 21st Sep 2011, 09:30 PM -
ISO30 or NMTB30 Slitting Saw Arbor- I'm looking for one.
By Anorak Bob in forum METALWORK GENERALReplies: 8Last Post: 9th Sep 2011, 02:15 PM -
Slitting Saw Operation
By electrosteam in forum METALWORK GENERALReplies: 16Last Post: 12th Jan 2010, 10:23 AM
