Results 1 to 3 of 3
    Jul 2011
    Adelaide
    837
    Default 6" Rotary table.
    I have the $345 that General Tools want for a Vertex HV6 but before I pull the trigger I was wondering if there was anything about that might be more interesting out there. My mill is small so 6" is as big as I could go.
    Mar 2017
    64
    221
    There might be; others might comment. There will be cheaper versions, but for what it's worth, I have a Vertex HV6 and have been happy with it. I also bought the dividing plates and tail stock. I made a mounting plate so I could mount a 3 jaw chuck on it. That improved versatility a lot. All been used a lot. Not being able angle the table hasn't been an issue for me, but it all depends on what job comes up I suppose. Good luck with your purchase. Cheers, Tony
    Sent from my SM-N976B using Tapatalk
    Oct 2008
    Cairns, Q
    666
    FWIW I also have a Vertex HV6 (the older version with four T slots which I personally prefer) and have been completely happy with it. I also have the dividing plates and Vertex tail stock. The quality of this Vertex tail stock - bought separately from the rotary table - is not up to the standard of my other Vertex tooling. Maybe I was just unlucky. The rotary table is a very versatile item of tooling: having owned one I wouldn't be without it.
    I have made a mount for a 4 1/2 inch 3 jaw chuck, and have a 6" front mounting 4 jaw chuck which mounts directly on the table using the table's T slots. Both can be used with the R/T in either the vertical or horizontal position.
    Also have made a 190 mm diameter plate which can be mounted using the table's T slots when the table is in the horizontal position. This can also be mounted on the lathe faceplate. It is drilled with a pattern of M8 tapped holes to give more alternatives for clamping small, odd shaped or oversized (for the R/T's diameter) objects, and can be transferred between the lathe and mill without disturbing workpiece setups if necessary.
    Frank.
  1. Vertex 6" HV Rotary Table Vernier Error
    By electrosteam in forum METALWORK GENERAL
    Last Post: 9th Apr 2017, 09:38 PM
  2. Replies: 9
    Last Post: 10th Jul 2015, 06:30 AM
  3. DONE: Hartford 8" inches Rotary indexing table made in USA sale or trade
    By thorens in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 22nd Oct 2012, 09:57 PM
  4. SOLD: Vertex 6" Rotary Table
    By SurfinNev in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 29th Oct 2010, 08:36 AM
  5. Vertex 6" Rotary Table Chart
    By wannabe in forum METALWORK GENERAL
    Last Post: 12th Dec 2008, 01:42 PM
