Results 1 to 4 of 4
    Feb 2009
    canberra
    46
    Default WTB- Advance lathe change gears
    I have an early Advance lathe that is missing all the change gears, and the banjo bracket.
    I'm going around in circles trying to work out the best way to get change gears, 3d printing plastic ones, or have a go at cutting them.
    I thought I'd ask here before I delve too far, would there be anyone out there that might have some usable gears?
    From what I've worked out, the gears are 20DP with a 14.5 degree pressure angle, and Myford gears match.
    Myford gears go for a fairly sturdy price on ebay and the likes, and to buy a set I'd exceed what I feel this lathe is probably worth, so I'm hoping there is someone on here that might have some gears kicking around that might work for me.
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,563
    A photo of an existing gear might help - some people have spares floating around and they can be adapted, provided that there is not a unique hub or something.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Gears should be 5/8” bore with 1/8” keyway not sure on the width.
    Good luck with your search but seeing that your lathe by your estimate is worth less than $150 you might be hard pressed to find gears for a lower price, you may fluke someone who will give them away.
    Feb 2009
    canberra
    46
    $150 is what I got the lathe for. I haven't seen a lot of sets going online, and individually they seem to be going in the range of $40 inc postage per gear. That might be OK if i was only looking for one or two.
    I just happened to pick up a set of myford gears from ebay for $120, so I'm all sorted for now.
    I'll make up the banjo bracket and gear studs to suite the lathe and the change gears.
    Cheers.
  1. Change gears for Premo lathe
    By Ruddy in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 1st Apr 2017, 10:03 PM
  2. al960 b lathe change gears to cut metric thread 3.5mm
    By B the B in forum METALWORK GENERAL
    Last Post: 14th Feb 2017, 09:59 AM
  3. Change gears and thread indicator for Steelmaster 1236A lathe
    By Grahame Collins in forum METALWORK GENERAL
    Last Post: 4th Jan 2013, 05:12 PM
  4. Extra lathe change gears?
    By Greg Q in forum METALWORK GENERAL
    Last Post: 15th May 2011, 09:39 PM
  5. Change gears for Hercus lathe model C?
    By neksmerj in forum THE HERCUS AREA
    Last Post: 20th Jul 2008, 01:03 PM
