Results 1 to 15 of 18
12th Feb 2020, 10:09 AM #1Member
- Oct 2019
- Nth Queensland
- 55
Buy face plate hercus 260 model atm
Missing the face plate for Hercus 260 Model ATM.
tham60
12th Feb 2020, 11:32 AM #2Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
14th Feb 2020, 03:45 PM #3Member
- Oct 2019
- Nth Queensland
- 55
Sorry should have mentioned I have in quired of Mal at AMH, has none (unusual I know)
Mal at AMH does not have one in stock.
14th Feb 2020, 09:12 PM #4Most Valued Member
- 4,887
You could make one from a weight.
15th Feb 2020, 03:01 PM #5Member
- Oct 2019
- Nth Queensland
- 55
I am a rank amateur having just started as a very new hobbyist. I am reasonable handy and am willing to try. Thankful for any guidance here.
15th Feb 2020, 03:34 PM #6Most Valued Member
- 4,887
Do you need or want the face plate?
17th Feb 2020, 02:45 PM #7Member
- Oct 2019
- Nth Queensland
- 55
Faceplate Hercs 260
Both. I believe that I will need same for a couple of exercises. e.g between centres for tapers where compound doesn't have the range?
Terry (tham60)
17th Feb 2020, 04:38 PM #8Most Valued Member
- 4,887
So is it a face plate used for work holding ( bolting things too that are awkward to hold in a chuck ) or a drive plate/ dog plate used for driving a lathe dog for between centres work you are after?
18th Feb 2020, 10:18 AM #9Member
- Oct 2019
- Nth Queensland
- 55
Faceplate/260
Pipeclay thanks for your patience, the dog plate in the fist instance. The difficult to bolt will come later for me I am thinking.
Terry (tham60)
18th Feb 2020, 10:28 AM #10Member
- Oct 2019
- Nth Queensland
- 55
Hercus 260 Faceplate.
Pipeclay, it would seem that Mal has a a dog plate in stock which I have ordered. However I will continue the search for faceplate.
18th Feb 2020, 11:38 AM #11Most Valued Member
- 4,887
Do you realise that you can use a normal chuck for your between centres turning?
If you really need a face plate I can make one.
19th Feb 2020, 09:49 PM #12Golden Member
- Oct 2001
- ACT
- 667
fairly sure I have a hercus faceplate. Can you measure the OD of your spindle thread and tpi? as didn;t the 260 spindle come in a couple of different sizes?
will try find it
19th Feb 2020, 11:18 PM #13Most Valued Member
- 4,887
Can you let me know what other threaded spindle sizes the 260 has different from 1 3/4” x 8.
20th Feb 2020, 03:03 PM #14Member
- Oct 2019
- Nth Queensland
- 55
Faceplate Hercus 260
Pipeclay/ Zsteve
Thank you for offer happy to reimburse for construction or supply??
Pipeclay it is 1 3/4 X 8 .
Apparently I understand there was an optional 1 3/8 X with a cam lock nose available.
tham60
20th Feb 2020, 05:37 PM #15Most Valued Member
- 4,887
If you end up getting one made do you want it as a bare plate or would you want slots in it ?
face plate
By shaper07 in forum THE HERCUS AREAReplies: 2Last Post: 13th Nov 2017, 09:54 PM -
hercus ,qualos lathe face plate and chuck back plates
By KBs PensNmore in forum METALWORK - Machinery, Equipment, MARKETReplies: 4Last Post: 7th May 2017, 02:13 PM -
Compact Workpiece Clamps for the face plate and angle plate.
By metaler in forum METALWORK PROJECTSReplies: 0Last Post: 10th Oct 2016, 07:16 AM -
Bernerd Model 34 4 Jaw Chuck - Face plate bolts?
By ventureoverland in forum THE HERCUS AREAReplies: 16Last Post: 20th Jul 2014, 06:07 PM -
Face plate fix
By Stustoys in forum METALWORK GENERALReplies: 35Last Post: 13th Nov 2010, 12:42 AM
