Results 1 to 6 of 6
Thread: Heavy wall brass or copper pipe
28th Jan 2020, 10:30 PM #1China
- Dec 2005
- South Australia
- 1,658
Wanted SA heavy wall brass or copper pipe, diameter 65-70mm, wall thickness 8mm, length 100mm ( to give me plenty of extra for stuff ups)
I do not know if this size is even available, just though I would ask because it will make my job simpler.
I am making a box hinge once complete it will be Gold plated.
Photo taken from CWS website
28th Jan 2020, 11:19 PM #2Most Valued Member
Can't help you with the material, but try your local scrappy for a brass gate valve. Probably 50mm would be about the size you're looking for, as it's 60mm OD, which should machine the hex down to your 75 OD with about 65 approx ID.
HTH
29th Jan 2020, 02:25 AM #3China
- Dec 2005
- South Australia
- 1,658
Only one local scrappy De Youngs the rest have all gone, finished size is 60 mm OD, but my skills on a metal lathe are pretty ordinary so I always need a bit extra to play with,
I am going to De Youngs tomorrow so I will see what the have they don't have a lot of that sort of gear these days
29th Jan 2020, 07:23 AM #4Philomath in training
8mm is a pretty solid wall for that diameter pipe. You might be better off cutting rings out of some thick plate with hole saws.
MichaelLast edited by Michael G; 29th Jan 2020 at 10:11 AM. Reason: removed size as plate won't necessarily be that thickness
29th Jan 2020, 02:50 PM #5China
- Dec 2005
- South Australia
- 1,658
Yes I thought of using thick plate it just complicates the process I would the have to mount them in the lathe chuck to finish them, the rings are not flat, one side has small recess to allow the timber to be attached I may resort to having some one make the rings and I can make and solder the hinge section on
29th Jan 2020, 03:13 PM #6China
- Dec 2005
- South Australia
- 1,658
Ok I have made some inquiries and the sizes I want are not available, so I have decided to fabricate the two halves in two pieces each out of sheet, I was just looking for a easy way out.
Small square of brass or copper
By racingtadpole in forum WANTED TO BUYReplies: 4Last Post: 28th Jan 2020, 08:31 PM -
Supplier for thin (4-6mm OD) copper or brass tubing
By StevenManos in forum METALWORK GENERALReplies: 6Last Post: 7th Jun 2016, 09:02 AM -
I want to make my first copper wall art
By tomk38 in forum METALWORK GENERALReplies: 2Last Post: 28th Nov 2013, 09:41 AM -
Brass/Copper finish
By cookie48 in forum METALWORK GENERALReplies: 2Last Post: 7th Jul 2011, 09:14 PM -
Silver solder repair to brass plumbing fitting in wall.
By Bouvard in forum METALWORK GENERALReplies: 14Last Post: 8th Dec 2010, 05:01 PM
