Results 1 to 9 of 9
Thread: Bead roller
14th Dec 2019, 09:33 AM #1Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,536
Bead roller
If anyone has bead roller and basic die sets they would like to part with please get in touch. I’m looking more along the lines of an industrial quality unit such as Heine, Edwards or Bramley. Having said that I’m smart enough to realise they are something of a unicorn so am prepared to consider anything that may be for sale. Preferably it will come with some basic beading dies but that’s not necessarily essential. Need a minimum throat of 300mm.
14th Dec 2019, 01:38 PM #2Most Valued Member
- 5,945
Found this on Gumtree, it's not cheap but that's what they seem to be going for.
https://www.gumtree.com.au/s-ad/moor...and/1224960408
Otherwise buy your set of dies and make one, that way you can have it manually or electrically operated, and whatever depth you need.
15th Dec 2019, 03:44 AM #3China
- Dec 2005
- South Australia
- 1,656
OK enlighten me is a jenny and a bead roller the same thing
15th Dec 2019, 11:04 AM #4Diamond Member
- Aug 2006
- 1,105
I always referred to them as swage and jenny. "Bead Roller" would be the modern term.
15th Dec 2019, 11:13 AM #5Most Valued Member
- 5,945
Found an interesting article to read. In answer to Chinas question, they are all one and the same. https://www.hotrod.com/articles/bead...eetmetal-work/
15th Dec 2019, 11:33 AM #6Most Valued Member
- Mar 2011
- 1,536
$1200 for that one on Gumtree is, well... we all know the quote from the movie. A powered unit of similar size and design can be had from Baleigh for not much more.
I’ve looked at buying a cheap eBay one and rehashing it for power and increased rigidity but honestly, if I’m going to do that I may as well just build from scratch. I would prefer to purchase a decent used unit but they are something of a unicorn. Of course if you don’t ask, you don’t know, who knows what’s laying around in peoples sheds and workshops.
15th Dec 2019, 02:49 PM #7
These are now sort after by people doing auto body fabrication.
Its a bit like the woodwork scene.
Industry disappeared and the gear was junk and dumped then a few enthusiasts and dilettantes got into making stuff and with everyone posting how good the old stuff was on the likes of feiceburk and instagrub you can’t buy this stuff unless your loaded.
Also like the woodwork scene a few companies started to reproduce improved copies of old classics like the bed rock planes and then the Chinese copied their copies and half decent stuff is now available for us peasants again.
Hare and Forbes get a line of Autobody gear made in China and they get some mates of mine at Motorretro to check it out and prove it. They do make mods to get it to work, the way the Chinese make it initially is a joke.
Its a bit like the Carbacrap Mini lathe, the white shoe man had it prototyped at Maryborough foundry and then got the Taiwanese to mass produce it.
Nice and cheap but every shipment had a change to the design. Always for the detriment of the lathe.
He had to fly over every time to fix it so he just gave up in the end.
I wouldnt be surprised to see Jet who are a huge company and have just bought out a few other players get into the metal side of things in the future.
H.Last edited by clear out; 15th Dec 2019 at 02:55 PM. Reason: Typo
Jimcracks for the rich and/or wealthy. (aka GKB '88)
15th Dec 2019, 03:53 PM #8Most Valued Member
- Mar 2011
- 1,536
Jet are already here, they are dealt by Interco Equipment and Carbatec.
16th Dec 2019, 11:33 AM #9
Swage n jenny is what ducting makers call them, Bead roller is what motor body builders call them.
Yes same thing in concept but its like a bandsaw it can metal or wood... and meat.
I had trouble with the H&F "bead roller" but they come to the party after much wasted too and froing, it still has its faults the main one has been addressed with the updated model being a soft start instead of a jolt(which is super frustrating on tight corners). I still think the quality of parts is questionable and the frame is not rigid enough for its 1.2mm rating as it still flexes sideways on .8mm(it could be rectified with some welded cross bracing between the side plates) , its still a very functionable unit providing you keep these limitations in mind.
Theres no real cheap option if you want a powered machine as the H&F is the cheapest at approx $2k, you could make one or just buy a hand cranked one... a lot cheaper than a proper swage n jenny....................................................................
RCD tripping on long welding bead - cause?
By desbromilow in forum METALWORK GENERALReplies: 8Last Post: 7th Feb 2019, 07:12 PM -
looking for a manunal swage and jenny, or a bead roller
By Opelblues2 in forum METALWORK GENERALReplies: 10Last Post: 13th Jan 2015, 10:13 PM -
Examining a fillet bead fracture
By Grahame Collins in forum WELDINGReplies: 17Last Post: 24th Aug 2014, 06:03 PM -
thin weld bead
By eskimo in forum WELDINGReplies: 19Last Post: 25th Nov 2012, 11:13 PM -
SOLD: New Bead Roller
By Greg Q in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 15th Feb 2012, 04:50 PM
