Page 3 of 3 FirstFirst 123
Results 31 to 34 of 34
Thread: CNC Build
  1. #31
    Jun 2020
    Freo
    69
    182
    Nothing is ever simple.
    I made the sockets in the A frame to fit the tube reasonably closely.
    The blue tube is fine but the black one isn't square or straight so now try milling it down to fit better
    Its 5mm wall so lose a a mil each side wont matter,
    Just extra work
  2. #32
    Jun 2020
    Freo
    69
    182
    Quote Originally Posted by pippin88 View Post
    I built my gantry so that the gantry beam sits on top of the uprights. This way not depending on my welds, and bolts just have to hold position, not load.
    I also made mine adjustable width, one end able to move in. A useful feature for getting into some spaces. But also improves load capacity.
    Probably should have done that on the bolted side but this was easy. The sliding side sits on the top, the bolts just lock it in position
    I liked the tube up the back and angle brackets to make sure it cant roll over.
  3. #33
    Jun 2020
    Freo
    69
    182
    I have my bench back
    Surprisingly enough it actually works
    The scales say 229kkg so not very heavy but more than this old bugger can lift.
    It rolls very nicely on the big soft wheels
    The column can have a rest on the base while the next bits get made
    A fair bit of welding is next on the agenda, finish these bits off before starting the base.
    The X-Y interface, for want of a better title, needs a lot more steel gluing on so that's next
    and then the spindle mounting parts can be finished up now that i have the corrected pieces of steel
  4. #34
    Jun 2020
    Freo
    69
    182
    The image upload seems to have reappeared so i can post a few.
    The XY interface is all glued together came in at 101Kg
    The pile of parts is getting bigger
    I welded up the spindle mounts and roughly machined the excess welds down a bit.
    After the heat treat the bore needs boring and facing so will finish the cleanup then
    The big tubes are on the bench and are awaiting some effort.
    Its so bloody hot and i like to do the grinding outside so that may get delayed till i come back from O/S.
    i fly out Next Monday night and the weather looks like bloody hot until i am gone.
    If it drops off a bit then i will do what i can but no rush
    Weights so far are about 420KG for the pile of parts on the stand
    The big tubes will get weighed when they are all stuck together
  1. CNC Build
    By grunto in forum CNC Forum
    Last Post: 16th Nov 2018, 10:32 PM
  2. A build thread
    By meadow street in forum WELDING
    Last Post: 26th Apr 2016, 06:29 PM
  3. help me build a basic flat build bed trailer for my kayaks
    By gros21 in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 13th Oct 2011, 08:47 AM
  4. Build or buy
    By smidsy in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 29th May 2011, 09:16 PM
  5. Trailer - to build or not to build
    By motegi in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 6th May 2009, 03:07 PM
