Results 1 to 3 of 3
Thread: Brierley ZB25 drill grinder
3rd Dec 2022, 08:41 AM #1
I'm starting a rebuild on a Brierley ZB25 drill grinder. I've gotten it from a guy who I'm sure was flogging off bits and bobs from the great GMH closure at Elizabeth in SA. The unit looked in fair condition but filthy with grinding dust.
So far I've dismantled it into its various sections and have started with the base.
The base has been grit blasted and I'm into the painting.
First coat is of etch primer followed by epoxy enamel. IMG_20221203_072137.jpgIMG_20221203_071830.jpg
Casting marks set in underside of base.
14th Dec 2022, 09:55 AM #2Senior Member
- Nov 2019
- Brisbane
- 69
- 452
Using a ZB25.
Hello from Brisbane.
I have been using a ZB25 for a few years and only found out I was using the rong cam for drills. A customer has one and his instructions state the No 4 cam is for jobber drills. I was using the No 1. The chuck wasn't alligned correctly. It was working but not well.
Keep us in the loop.
BC
17th Dec 2022, 09:20 PM #3
Hi steamloco1954, a no 1 cam is red, it is for lefthand tooling.
I have number 2,4,6,8,10 cams which should all be painted green these are the right-hand cams for right-hand tools.
Cheers Alby
Brierley drill grinder chuck size
By Peter Fou in forum METALWORK GENERALReplies: 15Last Post: 9th Dec 2022, 01:44 PM -
Much better drill grinder.
By steamloco1954 in forum METALWORK GENERALReplies: 0Last Post: 25th Jan 2020, 01:40 PM -
Large drill grinder
By steamloco1954 in forum METALWORK PROJECTSReplies: 0Last Post: 18th Jan 2020, 01:55 PM -
Brierley drill bit grinder cams
By nadroj in forum METALWORK GENERALReplies: 6Last Post: 29th Sep 2018, 06:53 AM -
Christen 2-32 Drill Grinder
By C-47 in forum METALWORK GENERALReplies: 0Last Post: 26th Jul 2015, 11:27 AM
