Results 16 to 30 of 42
10th Jan 2023, 12:08 AM #16
The Myford traveling steady has a fairly flat base and mounts with one screw but the fixed steady has a square feature in the base that snugly fits in the gap in the bed for precise centering.
Boxford lathes do resemble the Hercus 9” lathes with slight differences.
10th Jan 2023, 12:10 AM #17
22nd Feb 2023, 09:24 PM #18Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,195
4. Using lathe jaws, in between vice jaws, in a metal chop grinder:
When you are in a hurry, sometimes gotta grab whatever is on hand?Nigel, from a cave FULL of unfinished projects and lost tools.
1st Apr 2023, 10:14 PM #19Diamond Member
- Aug 2019
- 1,195
Boring an engine block
with a portable borer. Which is a little top-heavy, so had to stop the block from tipping off the bench:
IMG_4016.jpg IMG_4017.jpgNigel, from a cave FULL of unfinished projects and lost tools.
6th May 2023, 09:24 PM #20Diamond Member
- Aug 2019
- 1,195
Three things in a machining vice
Modifying the size of some T-slot nuts:
Now, we all know gripping 3 things doesn't work.
No matter how hood your vice is, how much you tighten it,
and how much you dead-blow hammer the things into the vice jaws,
two of the things will be gripped, and one will not.
Thankfully, in this case, the middle thing was loose.
I was milling slowly with a HSS cutter, so a little bounce and wobble is bearable.
Basically, the middle thing either slid away from the cutter until it hit the outer thing and was stopped,
or it bounced up and down until both the leading and trailing edge of the cutter face was over it.
Having the middle thing loose was actually helpful,
as I could remove it and test fit,
then slip it back into the vice for another cut.Nigel, from a cave FULL of unfinished projects and lost tools.
6th May 2023, 09:34 PM #21
6th Jul 2023, 10:20 AM #22Novice
- May 2023
- prestons nsw
- 76
- 21
Have used this type for many years in the vice, these days they are hard to come by
https://www.toolexchange.com.au/prod...-4-hold-downs/
6th Jul 2023, 01:24 PM #23
3rd Sep 2023, 09:37 PM #24Diamond Member
- Aug 2019
- 1,195
Lathe chuck clearance hack
Was boring a hole in a rectangular plate:
in the 4jaw, but the narrow side was too close to the chuck jaw step. So, when the cutter got too close, I wound out those two jaws, and put some HSS square there so that the boring would clear the jaws.Nigel, from a cave FULL of unfinished projects and lost tools.
3rd Sep 2023, 10:55 PM #25Most Valued Member
4th Sep 2023, 01:18 AM #26
Hi Kryn, Guys,
Now that is a useful tip ! Not just for multiple items but useful if the work isn't parallel vertically between the jaws.Best Regards:
4th Sep 2023, 03:10 PM #27Most Valued Member
- 2,671
I use Aluminium TIG wire all the time to hold parts for squaring stock.
Depending on which way it’s out of square you can put the wire vertically, horizontally or nearer the top or bottom of the jaw etc.
It’s soft enough to squash and conform and give a bit of friction.
I’m not a fan of hard on hard for clamping (particularly if there any chance of vibration) as there’s not much grip if things start to slide.
4th Sep 2023, 11:11 PM #28Most Valued Member
Have about half a 20litre drum of the stubs, about 150mm long, if anyone wants some.
The ape rentices can't be bothered joining the stub to a new rod.
23rd Oct 2023, 09:24 PM #29Diamond Member
- Aug 2019
- 1,195
Triangles in the bandsaw
Dividing a rectangle into two pointy triangles. I have tried it in the vice before, but the twist, and slip, when the blade breaks through it is risky, so:
IMG_4665.jpgNigel, from a cave FULL of unfinished projects and lost tools.
25th Oct 2023, 04:39 PM #30Gear expert in training
- 34
- 1,080
One of the guys at work had an interesting way of getting around protruding features...
Clipboard01.jpgGear cutting specialists and general engineers www.hardmanbros.com.au
How to Hold This?
By wm460 in forum METALWORK GENERALReplies: 7Last Post: 23rd Oct 2021, 05:21 PM -
How would you hold this?
By andrew_mx83 in forum METALWORK GENERALReplies: 15Last Post: 8th Jan 2014, 03:49 PM -
Roller grinder ways/ plain grinder ways
By Michael G in forum METALWORK GENERALReplies: 11Last Post: 6th May 2012, 12:37 AM -
How to hold a disk for machining
By rodm in forum METALWORK GENERALReplies: 7Last Post: 25th Apr 2009, 02:47 AM -
Uhh, strange things are afoot in these parts...
By Schtoo in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 18Last Post: 6th Nov 2005, 12:01 PM
