Page 1 of 3 123 LastLast
Results 1 to 15 of 42
    Aug 2019
    Revesby - Sydney Australia
    56
    1,185
    Default Strange ways to hold things before machining them?
    1) A restaurant needs some meat clamps. I bought some stainless u-bolts, and wing nuts, but to make it easier to push through the meat, the ends need to be pointier than this:
    Now, a sensible person would just grind a point on them and move on.
    I'm not sensible. I want to use a lathe.
    Have a chat with the toolmaker. We throw ideas around...
    V block on a rotary table? Rod chamfering cutter? Tiny chuck in larger chuck on the lathe?
    Then I spy a little collet chuck:
    which I can just mount in Adam's old Taylor chuck:
    (oops, that cutter will foul on the other side of the u-bolt)
    (and that one won't work on my Hercus because the spindle only goes forward)
    Yep, that worked:
    2. Reducing the size of a spade terminal. A 5x20 fuse holder melted. I bought a 3AG holder to replace it, but it has 6.3mm wide spades. Wiring has 4.8mm wide terminals. Spades are copper. I don't want to grind it.
    A sensible person would cut it narrower with some sharp cutters. I try to mill it. The spade rotates around, in the holder. Time for a tricky spacer behind the terminal:
    (hard to see, but that is a C shaped car engine bearing between the back of the space and the jaw)
    The second cut was a bit trickier to position a spacer.
    End result was acceptable. Not perfectly straight, but the smaller terminal locked on well enough:
    6,444
    Quote Originally Posted by nigelpearson View Post
    1)
    Hi Nigel,
    What's wrong with using a file ?
    Mar 2011
    Southern Flinders Ranges
    1,536
    Glad the chuck is getting used, although I’m currently rueing my decision to sell it.
    The forward placed jaws and scalloped body on the Taylor certainly help make that setup possible
    Jun 2011
    Melbourne, Australia
    129
    Glad all went well, but to my way of thinking, that U-bolt looked like it was just waiting to take off a finger
    Aug 2019
    56
    1,185
    Nothing
    That is usually the first tool I grab to use, but this copper was fairly thin, and then there is the difficulty of grabbing it:
    A smaller vice might have been able to grab it. Like maybe a pin vice:
    Anyway, a sharp milling cutter did each cut in 20 seconds. A file might have taken a minute or two
    Aug 2019
    56
    1,185
    Quote Originally Posted by Salv View Post
    Maybe. The u-bolt was 65mm wide (inside), so 77mm total, or 154mm swing.
    Hercus 9 can do 235mm around bed+saddle. Can nearly fit a fist in between there!
    The outer u-bolt end just fitted in a sweet spot under the left compound lock screw.
    I could have gone a few mm closer?
    Probably about as unsafe as any oddly shaped thing bolted to a lathe faceplate.
    Aug 2019
    56
    1,185
    3. Turning down a large rod, without steadies.
    14mm diameter stainless, over a metre long. Needs to become 12mm diameter.
    The big lathe is too close to the wall, and the rod has a handle and gear on one end,
    so I have to use the Hercus:
    Now, I have no steady for the Hercus, so I machine about 60mm at a time.
    Which means the rod hanging way out of the spindle:IMG_3829.jpg
    and whipping around a little. Hence the cardboard tube and rag.
    Lathe spindle was on its lowest non-back geared speed,
    next fastest would whip excessively.
    For the next few sections, I tried to reduce this whipping so I could turn/machine it faster.
    I happen to have a strange 14mm collet (thanks Peter), so:
    Cable tie didn't hold it for very long
    As the rod got further through the spindle, I put a bearing on the end, to hold onto it:
    That would be a human vibration damping system?
    I also worked out that the other end of the collet fitted in the end of the spindle well enough to stay in place:
    Getting there:
    I will eventually have to clamp that bearing - effectively making a stready.
    Nigel, from a cave FULL of unfinished projects and lost tools.
    Oct 2019
    Adelaide, SA
    1,201
    1m without steadies is way beyond my comfort level and I would never dare to do it
    Glad your improvised attempt worked.
    Aug 2019
    56
    1,185
    Default comfort level???
    Kafie, it was a bit beyond my comfort level, too!
    Eventually I mounted the bearing in the tailstock. It just fitted in an ER32 collet holder:
    With the tailstock all the way along my (short bed) Hercus, the slight bends in the rod became problematic. I had to grip the middle with a suede palmed glove:
    Today I borrowed a pair of Myford steadies (fixed and travelling),
    so I don't have to do the next rod 60mm at a time.
    Oct 2019
    Adelaide, SA
    1,201
    I never knew that the Myford steadies fit Hercus 9” beds. Are they a snug fit?
    Sep 2008
    Riddells Creek, Vic.
    831
    So your Hercus is working again, what was the problem with it?
    Aug 2019
    56
    1,185
    Quote Originally Posted by Techo1 View Post
    No, the motor is still operating at a third of its 3phase capacity. I'm just spinning it up by hand each time!
    Aug 2019
    56
    1,185
    Quote Originally Posted by kafie1980 View Post
    Myford steadies ... Are they a snug fit?
    Oops. Come to think of it, it might be a Boxford.
    Always get those two confused - similar names!
    e.g. Boxford mk3 Boxford AUD Lathe Photo Essay
    So far, have only tried the fixed steady. The V and the flat fitted OK.
    The locking plate (that clamps underneath the steady) was a little tight.
    The gap in the casting, between the V and the flat,
    which is usually underneath the tailstock,
    might be a fraction larger on the lathe I borrowed the steadies from.
    6,444
    The Myford "Travelling" steady is secured to the saddle with a single screw, 1/4" whit I think. Mine is sat in a box somewhere along with other bits and pieces that I haven't seen for years.
  15. #15
    May 2011
    Murray Bridge S Aust.
    5,945
    What's the bet, that the box is right on the bottom, of the last row you look through.
    It's usually the case for me anyway.
  1. How to Hold This?
    Last Post: 23rd Oct 2021, 05:21 PM
  2. How would you hold this?
    By andrew_mx83 in forum METALWORK GENERAL
    Last Post: 8th Jan 2014, 03:49 PM
  3. Roller grinder ways/ plain grinder ways
    Last Post: 6th May 2012, 12:37 AM
  4. How to hold a disk for machining
    By rodm in forum METALWORK GENERAL
    Last Post: 25th Apr 2009, 02:47 AM
  5. Uhh, strange things are afoot in these parts...
    By Schtoo in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 6th Nov 2005, 12:01 PM
