Results 1 to 8 of 8
27th Jun 2022, 12:28 PM #1Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,195
Threaded handles for machinist clamps
So, I have a pair of unfinished clamps without the threaded handles, and am trying to quickly finish them. Can't be bothered turning down stock, threading, knurning, and cross drilling.
(like a million apprentices have for centuries )
Threads are 3/8 Whitworth. Toolmaker suggested socket head screws, and weld/braze a rod as handle on to the top. Alas, I couldn't find cheap high tensile screws with decent thread length.
So, grabbed some cheap bolts from the "red hammer warehouse":
The "expanding" thread handle is easy. I just machine the end to fit the pocket:
The "tightening" handle requires some thought, though.
Needs a sleeve to clear the square lock under the bolt's dome head.
Or maybe bodgy some washers and weld the whole lot to a rod for the cranking handle?
27th Jun 2022, 05:07 PM #2
Hi Nigel,
I would have turned off the square under the head first !Best Regards:
29th Jun 2022, 09:39 PM #3Diamond Member
- Aug 2019
- 1,195
Fair enough. I was thinking that might weaken the bolt head,
...but it saved time looking for washers, so:
Then, ground some slots in the head, found some old 1/4" rod, bent a crank on one end:
and did some welding:
Sadly, on one of them I undercut the rod, and trying to build it up again failed.
Will have to find some more rod tomorrow
30th Jun 2022, 02:26 PM #4Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
That type of handle will really restrict the usability of the clamp.
30th Jun 2022, 06:34 PM #5Diamond Member
- Aug 2019
- 1,195
Restrict? Yes, they will get in the way sometimes, but cheap and fast sometimes wins out.
(often, for me)
The other way they restrict is not clamping below about 30mm:
because the thread on the expanding handle doesn't go far enough.
For now, I die cut its thread 10 or 15mm longer:
Eventually, I might make some better handles from booker (all thread) rod,
with machined/knurled/cross-drilled heads.
I would have gone that way initially, except that all the threaded rod I found was rubbish.
Either soft mild steel which is soooo loose that it would strip at first clamping,
or stainless that was better, but I don't trust to not gall or fail under stress.
1st Jul 2022, 12:20 AM #6Diamond Member
- N.W.Tasmania
- 1,407
Stainless probably not too much of a problem if the clamp jaws are not stainless as well. I agree that hi tensile thread would be better though, as would a much finer thread. Some of the model Engineer threads - either 32 or 40 tpi would give lots of clamping power.
1st Jul 2022, 12:56 PM #7Most Valued Member
- Healesville
- 2,129
1st Jul 2022, 08:49 PM #8Diamond Member
- Aug 2019
- 1,195
Indeed. I noticed that when cutting, so only did about half of the depth through the clamp blocks – to still provide some clamping strength.
Their steel is fairly nasty rubbish. Maybe from the bright galvanising?
I doubt they will last long, but I'm hoping soft thread in the handles will spare the threads in the clamp blocks.
Hammer handles.
By eskimo in forum GENERAL DISCUSSION / OFF TOPICReplies: 3Last Post: 8th Oct 2021, 10:32 AM -
Knife handles
By Old Croc in forum KNIFE MAKINGReplies: 10Last Post: 10th Sep 2020, 07:29 PM -
File handles.
By Old Croc in forum METALWORK GENERALReplies: 12Last Post: 6th Sep 2020, 12:17 PM -
SA-Tap Handles- Free
By racingtadpole in forum METALWORK - Machinery, Equipment, MARKETReplies: 6Last Post: 3rd Jul 2020, 07:17 PM -
Where can I buy Affordable Acme Threaded Lead Screw & Flanged Acme Threaded Nuts
By RoyG in forum METALWORK GENERALReplies: 8Last Post: 1st Sep 2014, 12:26 PM
