Results 1 to 3 of 3
    Aug 2016
    Adelaide
    80
    Default Machining dovetail straight edge
    I need to make a dovetail straight edge out of some cast iron bar.
    Is anyone in Adelaide interested in milling the flat & bevel faces? Or recommend a business that might do it for reasonable price.
    The plan is to scrape it flat after machining (and possibly grinding) so it can be used as a master to check cross slide ways on my hercus.
    It will be approximately 350mm long & about 50mmx30mm with approx 50degree beveled edge for the dovetails. I have a piece of cast iron that I will roughly cut to shape with bandsaw. Machining required is square up the faces and cut the bevel.
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    You'll need to supply some more detail, like how long and whether you are going to finish scrape it or are you looking for an off tool finish good enough (and possibly what are you using it for - it may need to be scraped)
    Oct 2011
    59
    6,561
    That will fit on my mill so potentially I could do that for you.
  1. Camelback straight edge
    By qb6sagr in forum METALWORK GENERAL
    Last Post: 11th Dec 2022, 11:57 AM
  2. Straight Edge.
    By Simplicity in forum METALWORK GENERAL
    Last Post: 10th Sep 2020, 09:05 PM
  3. Straight edge pattern in Vic.
    By greg_n in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 10th Aug 2020, 01:29 PM
  4. Large straight edge.
    By Old Croc in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 11th Dec 2019, 04:46 PM
  5. Dovetail straight edge & scraping dovetails
    By j3dprints in forum METALWORK GENERAL
    Last Post: 10th Apr 2018, 09:20 AM
