Results 1 to 3 of 3
Thread: DRO Install HF-46 Mill
27th Apr 2022, 01:28 PM #1Member
- May 2018
- Cairns, Qld.
- 70
Nothing unusual about this addition I guess. Done recently in March & April. Not an install that you can rush however, a fair bit of thinking required before drilling holes in important parts of the machine & cutting/bending metal.
The X axis was the (easy?) first one done as the two adjacent surfaces are hopefully square & parallel, though access was a bit problematic for drilling & tapping several 4mm mounting holes. Had to re-drill the oil hole access for the rear ways as it was covered over by the scale.
The Y axis scale required two 7 degree wedges made to adjust for the draft angle on the main base casting, whilst 2 aluminium brackets were fabricated to mount the reader head & allow the l/h end casting of the table to full travel inwards. Very fiddly with much measuring & triple-checking before drilling, tapping & bending.
The display unit mount bracket was bolted to the main vertical column, but you need to be mindful of the supplied flat attach bracket (made of a crappy aluminium casting) being bolted to the double-curved rear face of the column. Could easily snap said bracket if spacers not fitted.
I left the Z axis fitment for a couple of weeks whilst playing with the 2-axis features & checking & adjusting alignments.
The display unit has a couple of features added within the software that were not mentioned in the supplied poor 'Chinglish' instructions. This caused a bit of grief for a day or two until sorted out.
Last week I added the Z axis kit. It took a couple of iterations before I got the means of moving the reader head sorted-out satisfactorily & in reasonable alignment.
I did not use any of the other supplied aluminium mount brackets & plates of the 'mill install kit' as they were totally unsuited to this install. However, there was plenty of general hardware, shims & p-clips for the job. I only broke the very tip off one 4mm taper tap & that was just at the entry to a drilled hole, so that was extracted easily.. I had to use a right-angle drive adaptor on the battery drill to enable access for the X axis mount holes in the rear of the table & saddle, even with it wound fully forward. Steady hands needed there. Perhaps a more compact drill would have been easier?
Pictures below...
Now to put it to good use.
H614
Note It is an HM-46 mill. Can't change the title.Last edited by Halifax614; 27th Apr 2022 at 01:40 PM. Reason: Tidy up
27th Apr 2022, 05:41 PM #2Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,554
Very similar to how I mounted mine up on my 45 size mill
27th Apr 2022, 08:50 PM #3Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,195
Nice brackets on the Y-axis!
DRO cables on lathe - install ideas
By bollie7 in forum METALWORK GENERALReplies: 4Last Post: 7th May 2020, 09:28 PM -
Licensed electrician to install?
By lamestllama in forum ELECTRICALSReplies: 8Last Post: 31st Aug 2019, 05:12 PM -
MD45/HM46/RF45 DRO Install as requested..
By variant22 in forum METALWORK GENERALReplies: 42Last Post: 15th Jul 2017, 09:09 PM -
Install of 3 axis DRO on a Victoria universal mill
By richo132 in forum METALWORK GENERALReplies: 6Last Post: 28th Dec 2016, 08:27 PM -
DRO Install
By Oldneweng in forum METALWORK GENERALReplies: 35Last Post: 28th Sep 2016, 12:36 PM
