Results 121 to 135 of 178
Thread: Biax/Bunax making group project
13th Mar 2022, 09:54 AM #121
This is where I got to last night. I'll cut it off and finish it tonight....
Cheers, Joe
13th Mar 2022, 10:58 PM #122Cheers, Joe
14th Mar 2022, 07:40 AM #123Most Valued Member
I just had another look Joe.
I saw you removed the bottom part to allow room to move.
I'll be interested to see the finished product.
Sent from a galaxy far far awayGirl, I don't wanna know about your mild-mannered alter ego or anything like that." I mean, you tell me you're, uh, super-mega-ultra-lightning babe? That's all right with me. I'm good. I'm good.
17th Mar 2022, 11:03 AM #124Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 831
This is my candidate for a scraper conversion, it is a 30 year old Milwaukee Sawzall that use a Wobble Shaft to drive the Reciprocating shaft back and forth. I have already done some minor modifications to allow the handle to be flipped over, that is why the lettering on the side is upside down.
18th Mar 2022, 02:36 PM #125
That's the perfect shape!
Being as old as that probably means that all the insides are steel rather than powdermetal.
Good luck and keep photos coming!Cheers, Joe
18th Mar 2022, 04:32 PM #126Most Valued Member
That looks like a little ripper!
Can't wait to watch your progress.
My power scraper project will have to wait a week or so. I just come out of hospital to fix a hernia. I. A bit delicate ATM!
19th Mar 2022, 09:27 AM #127Most Valued Member
A little late on this as you guys seem to be almost there with the insides.
On mine I used different thread sizes on the adjuster so you know which way you adjusting the stroke(as the slide is at 90 to the travel it doesn't move), but given it would seem your min speed is pretty slow you can likely just watch if your on the four stroke or the back stroke.
19th Mar 2022, 09:36 AM #128Most Valued Member
Thats a good point Stu. I hadn't thought of that!
ATM I have nuts for the spacer as I am yet to make the spacer so I can actually see inside and know which way it's facing.
I guess I can just buzz the motor slowly and watch the stroke movement to identify which side is which?
I would have to mark the direction of rotation on the case as well.
19th Mar 2022, 09:58 PM #129
You make a very good point, Stew! I think I might use a black grubscrew one one side and a stainless steel grubscrew the other. It would be super annoying accidentally adjusting the pivot the wrong way...
Cheers, Joe
19th Mar 2022, 10:05 PM #130
Finished my blade holders. Next to mount them on the Makita....
Speedy recovery Simon!Cheers, Joe
20th Mar 2022, 09:09 AM #131Most Valued Member
Perhaps you could add a spring loaded stop that you "run into" that lines things up the way you want them?
(this assumes, 1. you can run the motor fairly slowly. 2. that the operator isn't an idiot)
20th Mar 2022, 12:02 PM #132Most Valued Member
20th Mar 2022, 12:04 PM #133Most Valued Member
20th Mar 2022, 12:10 PM #134Most Valued Member
I'm just going to write myself a procedure;
Buzz the motor until it finishes the retracting stoke (all the way in) and then turning both Allen keys to the front increases the stroke.
Edit: I just looked at my previous photos I posted. The above idea actually won't work. I'll have to buzz the motor until it's halfway along the inward retracting stroke AND then turning the Allen keys rearward increases the stroke.
What could possibly go wrong?....... Hmmmm. I think I'll organise some kind of visual identification like Joe.
8th Apr 2022, 01:42 PM #135Golden Member
- Sep 2008
- 831
The first real bit of progress towards turning the old Sawzall into a Scrapezall, a new shaft to replace the fixed angle wobble shaft. The original shaft has a 14 degree angle on the wobble journal that produces 3/4" of reciprocation.
The new shaft will allow adjustable stroke from zero to about 3/8",if I can reverse engineer all the angles and dimensions required to make the rest of the wobble mechanism, from some scaled up photos I got from the internet.
Biax anyone?
By jhovel in forum METALWORK GENERALReplies: 0Last Post: 29th Oct 2015, 04:37 PM -
Biax flaker anyone?
By jhovel in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 23rd Jun 2014, 01:58 AM -
What's a new Biax worth (to you)?
By Michael G in forum METALWORK GENERALReplies: 7Last Post: 11th Mar 2013, 12:28 PM -
Group or link all Group Buys into a sub-forum such as Member Deals
By Bitslong in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 1Last Post: 24th Jun 2009, 12:10 AM
