Results 46 to 60 of 178
Thread: Biax/Bunax making group project
28th Jan 2022, 06:55 PM #46Most Valued Member
Thats great. What a bargain!
Variety of make/models is good!
Can't wait to see it apart.
Sent from a galaxy far far awayGirl, I don't wanna know about your mild-mannered alter ego or anything like that." I mean, you tell me you're, uh, super-mega-ultra-lightning babe? That's all right with me. I'm good. I'm good.
28th Jan 2022, 10:27 PM #47
My brand new $140 Makita turned up today. Have had a little play with it. It has variable speed from 0-2800spm but by trigger pressure. I'll see if I can fit a Bosch wheel speed controller I have here. Otherwise I'll use the speed control box I use with many of my other single speed tools - including the vacuum cleaner when I use it as a blower
I may get a chance to open the gearbox later tonight or tomorrow. I'll take photos and may then make a suggestion of how a mod could work with this model.
The weight seems about right.Cheers, Joe
29th Jan 2022, 05:52 PM #48
Here we go....
I've pulled the Makita apart to have a look what's possible and what's not.
Findings: The crown gear does not have a counterweight. It is made from powder metal and is way too hard to machine.
Secondly, the needle roller bearing it runs on takes up the full thickness of the gear.
There is no space to add anything on top of the gear within the housing space as it stands.
Suggestions: As 'Stustoys' did way back, one could add a layer in between the housing halves to gain enough height for an adjustable sliding mechanism for the eccentric pin, By fixing an additional disk onto the top of the crownwheel gear, eg with a dovetail or T-slot in it, which in turn holds the eccentric pin. I'll do some measuring and thinking....
That would allow complete reversal of the internal modification.
I haven't yet looked at the blade holding mechanism. Further thoughts coming soon.Cheers, Joe
29th Jan 2022, 09:08 PM #49
Alright. I pulled the 'plunger' and it's bearing blocks out. The plunger rod is hardened and runs in two powder metal blocks (square section). The Scotch yoke appears to be welded onto the rod before grinding, and has a hardened steel slide to stop it tilting axially.
So far, an oder of magnitude better than the Aldi machine, engineering wise.
Once the blade holding mechanism was off, the end is just a 14mm dia. round rod with a slot in it. Would be very easy to make a scraper blade holder to fit over that and clamp on.
I'm playing with CAD at the moment to come up with some preliminary drawings for an adjustable stroke mechanism.
More later.
Cheers, JoeCheers, Joe
30th Jan 2022, 07:28 AM #50Most Valued Member
Thanks Joe. I'll be interested to see what you come up with.
Interestingly, the model I bought, JR3050T the parts diagram shows a slightly different shaped Scotch yoke.
30th Jan 2022, 08:48 AM #51Most Valued Member
- 4,258
30th Jan 2022, 04:56 PM #52
Here are my (CAD) thoughts for the stroke adjustment mechanism to go on top of the crown wheel:
Makita Saw Conversion v5 (Small).jpg Fixed block v2 (Small).png Slide v1 (Small).png
I'm thinking I'll make a set in the next couple of weeks and see what works.
I think the work flow would be: turn the round disk with the eccenter pin on the bottom to locate it (may need to try and drill another small hole for a second pinon the opposite side); cross-drill the disk from the solid end to the centre hole and tap it; then mill the dovetail slot; machine the dovetail slide and screwed-in adjuster in one piece for a tight fit. Cut off the slide part and screw in the short adjuster bit; then cross-drill through that and tap it in situ (maybe with the slide already in final position). The hole for the yoke bearing pin needs to be tight and accurately square, obviously.
Grub screws from both sides will lock the slide in position. An alternative would be a longer slide with a one-sided adjustment screw with a captive cross pin in a groove - will give that a bit more thought....
Making the housing spacer out of a sheet of 6mm aluminium should be straightforward.Cheers, Joe
30th Jan 2022, 05:19 PM #53Golden Member
- Apr 2019
- 596
Anybody remember the GMC tools sold by Bunnings 20 years ago? Definitely suspect tools in terms of durability. Bunnings have since switched to the XU1 tools and now the Ozito. They would be very unlikely to put their reputation against tools that do not last. Built cheaper...yes. Not for heavy commercial use....yes. Light duty home use.....great bang for buck. Everybody has their own experiences with these tools and each is easier/harder on them than the next. I have an XU1 1/4 sheet sander that is still going after 20 years. I had an Ozito demo hammer that I killed on a 35+ degree day by working it wayyyy to hard and long. The replacement is going great.
My Biax copy is based on the Ozito 850W router body. I have 100% faith in it lasting the distance as it is way over powered for scrapping so should just pur along at less than 50% load. Only issue is that I have had to design a multiple compound gear gearbox to achieve a 21:1 speed reduction.
30th Jan 2022, 10:26 PM #54Most Valued Member
- 2,672
Looks good Joe.
The square internal corners in the dovetail might be a challenge
I know that's not how you're intending it to be, but I started to think about how it could be done if actually needed.
Milling the shoulders off the disc and bolting on solid blocks would do it - like this:
Might even be an easier alternate way to do one (or both) ends instead of the small drilled and tapped dovetail piece you've drawn.
Just musing...
30th Jan 2022, 10:39 PM #55Most Valued Member
- 2,672
Opened up the used Bosch GSA900 I picked up yesterday.
Very similar design to the Ozito that was posted earlier in the thread.
Shaft is fixed in the crownwheel and rotates in 2 standard ball bearing races.
The output rod from the yoke to the blade is a rectangular section with a twist just before the blade holder to change the orientation from horizontal to vertical.
Edit: I did a quick file test and the back of the crownwheel appears soft enough to machine.
31st Jan 2022, 02:47 AM #56
@Steve: the square cornered/ended dovetail ist just my shortcut in CAD. I would have taken me another half hour to make it a semicircular end....the slider however can relatively easily be milled with a semicircular end to get full support and constraint at the shortest stroke end of travel.
Bolting anything to the powder metal gear is the hard bit! I'm envisaging having to grind any holes with a diamond burr in a container of water....
Even making a countersink on the existing hole for a screw - instead of the pin I drew on the round part would be a grinding operation.
I might try making a hole in the gear in the next day or so and find out what will cut it....Cheers, Joe
31st Jan 2022, 02:52 AM #57
@Mk1_oz: have you put some photos of your Ozito'ax on this forum? If so, link please. If not, please do.
My Ozito multitool driven real Biax head lasted maybe 2 hours. I've got an old Metabo jig saw motor which is what Biax used in their previous model (before Metabo made it obsolete). I'll be making an adapter to drive it with that next.Cheers, Joe
31st Jan 2022, 09:15 AM #58Most Valued Member
- 2,672
Joe - a solid rivet might be a good connection method between the crownwheel and the new part.
Would only need a hole - nothing precisely sized etc.
31st Jan 2022, 11:32 AM #59
Just tried and succeeded in drilling 2 small hoes through the hard gear using a new tungsten carbide drill bit.
So not quite as hard as I initially expected.Cheers, Joe
31st Jan 2022, 12:53 PM #60Most Valued Member
Very good. So do you think a HSS drill bit will go anywhere near it?
Biax anyone?
By jhovel in forum METALWORK GENERALReplies: 0Last Post: 29th Oct 2015, 04:37 PM -
Biax flaker anyone?
By jhovel in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 23rd Jun 2014, 01:58 AM -
What's a new Biax worth (to you)?
By Michael G in forum METALWORK GENERALReplies: 7Last Post: 11th Mar 2013, 12:28 PM -
Group or link all Group Buys into a sub-forum such as Member Deals
By Bitslong in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 1Last Post: 24th Jun 2009, 12:10 AM
