Results 61 to 64 of 64
Thread: DIY sandblasting cabinet
17th Jul 2022, 05:42 PM #61
Got the glass fitted and also fitted a screen mesh behind the glass,could not get the fold marks out of the mesh so it's a bit hard to see but will try it out. Need to order new rubber gloves the left one already has a couple of splits in it Stated working on the dust collecting system. OH!! and the bloody air valve is still tripping the circuit breaker I have a sparky coming over next week to get this problem work out i give up.
Tatra parts 013.jpgIMG_8946.jpgIMG_8947.jpgIMG_8948.jpgIMG_8950.jpgIMG_8951.jpg
17th Jul 2022, 06:33 PM #62
Hi Mark,
I don't know whether it will work for you, but I use a hard rubber roller to iron out kinks in wire mesh and thin sheet material. You will need to do this on a hard surface like a sheet of glass. I have a marble plate that I use.
I made mine from a scrap photocopier feed roller by turning the rubber off at the ends so that I could support the steel spindle with simple holes drilled into a bent piece of flat steel. Mine is about 6" inches long with a wood handle. I've also used it to spread ink when printing engravings and pressing the paper onto the plate.Best Regards:
17th Jul 2022, 06:43 PM #63
5th Aug 2022, 02:54 PM #64
I can now say that this project is finish and working great Still need to do some adjustments, started with some walnut shells first have some glass beads and some garnet blast media to try out as well. I work out the air solenoid valve,very easy no need for a sparky
Tatra parts 027.jpgTatra parts 028.jpgTatra parts 029.jpgTatra parts 030.jpg
Mill Cabinet
By Blu_Rock in forum METALWORK GENERALReplies: 6Last Post: 9th Apr 2012, 10:08 AM -
welding rod cabinet
By gracoope in forum WELDINGReplies: 0Last Post: 16th Nov 2010, 11:14 PM -
Sandblasting contact details
By jackaroo in forum METALWORK GENERALReplies: 3Last Post: 22nd Apr 2008, 09:34 AM -
Gun Cabinet
By smidsy in forum METALWORK GENERALReplies: 11Last Post: 25th Jul 2005, 11:17 AM
