Results 31 to 45 of 64
Thread: DIY sandblasting cabinet
16th Feb 2022, 09:44 PM #31
All depends on your location, if there is already 3ph distribution running past the property then generally no too much headache. But if the service is not in place then you will need to pay for the service to be connected to your point of supply.
Likewise upgrading the 1ph supply, in some locations that will depend on the step down transformer feeding that area, if it’s already fully subscribed you will pay for its upgrade.
Personally have not looked at my current address. But connection is one thing, then I would need to factor in conversion or replacement of all the current 1ph toys that I have
17th Feb 2022, 04:56 AM #32
19th Feb 2022, 08:48 PM #33Diamond Member
- Jun 2010
- Canberra
- 1,322
Getting 3 phase can be a variable experience. At a property I work at, there was HV running along the edge of the property. but no transformers any where near. where we needed power. From memory it was about $40k to run about 1km of HV off the existing lines to a 63kVa transformer, which we paid for, but the distributor owns, somehow. That was probably 10 years ago. Might cost just a little more these days...
At my property, there's 3 phase LV running down the street. Upgrade of the line in and metering was completely free, I assume because the retailer/distributor thought we'd be using more power.
23rd Feb 2022, 01:58 PM #34
Almost finish off the sheet metal work, have tomorrow off from work see if i can get a lot more done on the sheet metal work.
IMG_8846.jpgIMG_8845.jpgsandblasting cabinet 001.jpgsandblasting cabinet 002.jpgsandblasting cabinet 003.jpg
11th Mar 2022, 05:46 PM #35
Lot of welding,cutting and grinding done on the cabinet so far. fitted a 20W LED light and stared working on the door.
sandblasting cabinet 008.jpgsandblasting cabinet 010.jpgsandblasting cabinet 011.jpgsandblasting cabinet 012.jpgsandblasting cabinet 005.jpgsandblasting cabinet 013.jpg
8th Apr 2022, 02:26 PM #36
Got some paint on the cabinet and finish off the door and sealed all joints with silicone sealer.
medical certificate 001.jpgmedical certificate 002.jpgmedical certificate 003.jpgmedical certificate 004.jpgmedical certificate 005.jpg
9th Apr 2022, 08:28 AM #37Most Valued Member
Wow, that's alot of work but it looks fantastic!
Nice size too.
Sent from a galaxy far far awayGirl, I don't wanna know about your mild-mannered alter ego or anything like that." I mean, you tell me you're, uh, super-mega-ultra-lightning babe? That's all right with me. I'm good. I'm good.
9th Apr 2022, 10:45 AM #38
9th Apr 2022, 01:57 PM #39
Looks great!
9th Apr 2022, 02:10 PM #40
11th Apr 2022, 11:28 AM #41Golden Member
- Dec 2007
- 574
That's a great job - I wish I had the room to house something like that - I recently purchased a gravity fed sand blasting gun - it does work to a degree but makes such a mess - sand gets into everything - I should have worn a hat - I had to have a shower before coming in for the evening - sand dropped out of my clothing and hair everytime I sat down somewhere.
11th Apr 2022, 01:49 PM #42
Lining
Looks nice
I believe you can line the inside with canvas , the canvas absorbs or slows down the speed of the abrasive particles as they bounce off the walls, the abrasive particles can cloud up the workspace which makes it harder to see what is going on.
11th Apr 2022, 02:03 PM #43Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Will you use a water trap on the vacuum side?
11th Apr 2022, 02:38 PM #44
11th Apr 2022, 02:42 PM #45
Mill Cabinet
By Blu_Rock in forum METALWORK GENERALReplies: 6Last Post: 9th Apr 2012, 10:08 AM -
welding rod cabinet
By gracoope in forum WELDINGReplies: 0Last Post: 16th Nov 2010, 11:14 PM -
Sandblasting contact details
By jackaroo in forum METALWORK GENERALReplies: 3Last Post: 22nd Apr 2008, 09:34 AM -
Gun Cabinet
By smidsy in forum METALWORK GENERALReplies: 11Last Post: 25th Jul 2005, 11:17 AM
