Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 64
  1. #31
    Sep 2005
    Bendigo
    60
    419
    Quote Originally Posted by Turbine Builder View Post
    Have you look into getting 3 phase? It's not as hard as you might think, cost me 4K all up could got it cheaper by installing the cable my self and have the sparky do the rest.
    All depends on your location, if there is already 3ph distribution running past the property then generally no too much headache. But if the service is not in place then you will need to pay for the service to be connected to your point of supply.
    Likewise upgrading the 1ph supply, in some locations that will depend on the step down transformer feeding that area, if it’s already fully subscribed you will pay for its upgrade.
    Personally have not looked at my current address. But connection is one thing, then I would need to factor in conversion or replacement of all the current 1ph toys that I have
  2. #32
    Oct 2016
    470
    Quote Originally Posted by droog View Post
    Just contact your power supply company they will know wouldn't hurt to find out. As for your 1ph toys sell them that's what i did, sold the lathe and milling machine. Then i got a couple of real mans toys 1.8 ton Okuma lathe and 1.4 ton Rambaudi mill.
  3. #33
    Jun 2010
    Canberra
    1,322
    Getting 3 phase can be a variable experience. At a property I work at, there was HV running along the edge of the property. but no transformers any where near. where we needed power. From memory it was about $40k to run about 1km of HV off the existing lines to a 63kVa transformer, which we paid for, but the distributor owns, somehow. That was probably 10 years ago. Might cost just a little more these days...
    At my property, there's 3 phase LV running down the street. Upgrade of the line in and metering was completely free, I assume because the retailer/distributor thought we'd be using more power.
  4. #34
    Oct 2016
    470
    Almost finish off the sheet metal work, have tomorrow off from work see if i can get a lot more done on the sheet metal work.
    IMG_8846.jpgIMG_8845.jpgsandblasting cabinet 001.jpgsandblasting cabinet 002.jpgsandblasting cabinet 003.jpg
  5. #35
    Oct 2016
    470
    Lot of welding,cutting and grinding done on the cabinet so far. fitted a 20W LED light and stared working on the door.
    sandblasting cabinet 008.jpgsandblasting cabinet 010.jpgsandblasting cabinet 011.jpgsandblasting cabinet 012.jpg
  6. #36
    Oct 2016
    470
    Got some paint on the cabinet and finish off the door and sealed all joints with silicone sealer.
    medical certificate 001.jpgmedical certificate 002.jpgmedical certificate 003.jpgmedical certificate 004.jpgmedical certificate 005.jpg
  7. #37
    Aug 2011
    4,779
    Wow, that's alot of work but it looks fantastic!
    Nice size too.
    Sent from a galaxy far far away
  8. #38
    Oct 2016
    470
    Nice size too.
    Thanks mate Yeah still a lot more work to do like glass and screen filter needs to be made up. Electrical and plumbing fitted on the cabinet and a dust collection system, then it will be ready to use.
  9. #39
    Jan 2004
    Mackay North Qld
    6,446
    Looks great!
  10. #40
    Oct 2016
    470
    Looks great!
    Thank you sir, amazing what a bit of paint can do
  11. #41
    Dec 2007
    Adelaide
    574
    That's a great job - I wish I had the room to house something like that - I recently purchased a gravity fed sand blasting gun - it does work to a degree but makes such a mess - sand gets into everything - I should have worn a hat - I had to have a shower before coming in for the evening - sand dropped out of my clothing and hair everytime I sat down somewhere.
  12. #42
    Jul 2008
    near Warragul, Victoria
    3,718
    Default Lining
    Looks nice
    I believe you can line the inside with canvas , the canvas absorbs or slows down the speed of the abrasive particles as they bounce off the walls, the abrasive particles can cloud up the workspace which makes it harder to see what is going on.
  13. #43
    Jan 2016
    Wodonga Vic
    38
    633
    Will you use a water trap on the vacuum side?
  14. #44
    Oct 2016
    470
    Looks nice
    Thanks, what i have seen is you can use Stainless Steel 120 Mesh and place it ~ 6mm from the glass which should slow down the particles.
  15. #45
    Oct 2016
    470
    Quote Originally Posted by NedsHead View Post
    No will make up a cyclone dust collector system.
  1. Mill Cabinet
    By Blu_Rock in forum METALWORK GENERAL
    Last Post: 9th Apr 2012, 10:08 AM
  2. welding rod cabinet
    By gracoope in forum WELDING
    Last Post: 16th Nov 2010, 11:14 PM
  3. Sandblasting contact details
    By jackaroo in forum METALWORK GENERAL
    Last Post: 22nd Apr 2008, 09:34 AM
  4. Gun Cabinet
    By smidsy in forum METALWORK GENERAL
    Last Post: 25th Jul 2005, 11:17 AM
